Battery operated hatch pt. II
Old 03-29-2008, 05:56 AM   #11
Hi Brian,
There were three seating options in 94 for the Bow Riders and your seating is considered Option #2 - "Driver Bucket Seat". Your Talari is still a "Z" model.
Take a look at the 94 Brochure, about 4 pages from the end shows the seating options.
Our 96 Z240 Talari has Option #4 "Super Sport Interior" which is the dual bucket seats and large sun deck and no hatch lift was offered.
Dwayne Young likes this.
  • Old 04-01-2008, 07:37 PM   #12
    Paul F's Avatar
    Paul F is currently offline
    Gallery Images: 4
    Send Paul F:
    Don't know that I would want a power hatch.
    I'm not patient enough to wait for it to raise!
    Old 04-01-2008, 11:08 PM   #13
    Hey Paul,
    I got some Low-rider friends who could hook you up with some hydro-lifts and get that hatch open really quick!!
    Just make sure there's no one on the Sunpad when you open it or it's "Houston, we have a launch!"
    Old 04-16-2008, 03:25 PM   #14
    edward cossey's Avatar
    edward cossey is currently offline
    Status: Ed Cossey ( sonny boy )
    My Model: 1998 Z252 Shabah Mercr
    My Engine: 7.4L Bravo 111"
    Gallery Images: 4
    Send edward cossey:
    Default power hatch
    hi guys
    My Z252 Shabah has the power hatch disconnected, with two gas struts in its place, i think the preivious owner disconected it to fit a battery power switch in the motor compartment. i would like to refit the power lift , but wondering how to refit the battery power switch in a better position , so i can switch on from the boat deck instead of lifting the hatch first
    Ed Cossey
    Old 04-17-2008, 04:50 AM   #15
    Hi Ed,
    Normally it's just a matter of relocating the switch and replacing all the existing wiring with longer wire to the new location, I would not try to splice additional wire to the existing wire for safety's sake.
    If the new location is a considerable distance from the old location, I recommend consulting with someone knowledgeable in these systems as you may need heavier gauge wiring.
    It's especially important to do the job right the first time when it comes to boats, wouldn't want any electrical fires spoiling your fun!
    Old 04-17-2008, 02:38 PM   #16
    Gallery Images: 4
    Send edward cossey:
    Default battery switch
    Hey WetWilly
    thanks for the info, sounds good. i think I'll let you be my boat guru
    Ed
    Old 04-17-2008, 07:25 PM   #17
    Any time, Ed!
    Old 05-31-2008, 01:09 PM   #18
    dharby is currently offline
    My Model: 1994 Z220 Talari 350 Mag
    Send dharby:
    Well, my sundeck power lift problem was fixed for about a year (stopped working last year, found a corroded fuse). Now I have a strange occurence where one of the two lifts stops working - and after the boat sitting for a while, starts working again.?
    When I could see one side working and not the other, I flipped up the seat and pulled the tube out that way. The next morning I went out to work on it and both lifts worked perfectly. 2 weeks later - after rewiring the connections by the lift - the same sequence of events. I don't think it is the switch as I tried it MANY times (seeking a bad switch connection). It's almost as if it trips a breaker - which is reset after a good night's sleep .
    Any tips?
    1994 Talari z220 350 magnum
    Old 06-01-2008, 03:24 PM   #19
    Gallery Images: 4
    Send edward cossey:
    Default Power Hatch Lift
    Hi Guys
    appologies for my absence, but my wife had an operation and has been a pain in the a*** but she's better now, I posted some questions about Power Hatch lifts a while ago, my Z252 has had it disconected and Gas struts put in place, i wanted to put the power lift back, but this ment moving the battery switch from under the engine compartment, after reading the latest postings i think the gas struts are the better option, a bit of muscle won't hurt and could be easier than trying to lift the hatch if i get a flat battery, also the thought that the circuit breaker could fail would be a pain. it's great to see all the pins on the member map. if we get many more members in the States the map would need to be enlarged.
    i have not seen my boat since March and getting a bit broody, but i will be in florida for a month in july and i will for shure put plenty of hours on her
    all the best
    Ed Cossey (sonny boy)
    Old 06-02-2008, 03:37 AM   #20
    Originally Posted by edward cossey View Post
    i have not seen my boat since March and getting a bit broody, but i will be in florida for a month in july and i will for shure put plenty of hours on her:
    Hi Ed,
    While you're having fun with your Mariah, make sure to get some snap shots and put them on the galley for the rest of us to admire!
    Funny but our Z240 didn't come with a power lift, so I replaced the current gas shocks with a fresh set of 120lb gas shocks off of eBay (Great price, I highly recommend the seller). What a difference, it still takes a little effort to initially open the hatch but after that it's a lot easier and a little past half way, it goes up by itself and stays there, cool!
    Help! Need info on Engine Hatch Lift - Z302 milemarker60 Original Mariah Talk 6 07-13-2022 10:58 AM
    Battery Operated Hatch - Release Mechanism EBO Original Mariah Talk 10 02-03-2008 12:27 AM
    96 talari Z240 Engine Hatch Lift Help WetWilly Original Mariah Talk 8 10-02-2007 12:30 PM
    Battery Monitoring ShabahZ280 Boating 101 1 09-10-2007 11:31 PM
    Battery box full of water dudders General Maintenance 5 08-28-2007 12:35 PM
    There are 314 users
