Shower Questions
Old 07-31-2012, 04:30 AM   #1
michelleprms is currently offline
My Model: mariah jubilee 214d
My Engine: 350 mercruiser
Send michelleprms:
Default Shower Questions
this is not an answer but i hope that someone reads this and helps me i have no manual for my 99 214d mariah jubilee and i looked at the manual pdf version that was provided on here however there is no information for my water, shower and sink and i was trying to figure it all out the sink looks like it just hooks up to a bladder bag but the shower nozzel come out of side where fresh water gets put into the boat. if anyone has any advise or suggestions that would be awesome.
  • Old 07-31-2012, 08:26 PM   #2
    Default Re: Shower Questions
    To the best of my knowledge, the shower runs on raw water pumped from a pickup below the boat. I don't believe there's a holding tank on board the Jubilees, but I could be wrong. So there should be a switch for the electric pump somewhere around the showerhead.
    Is there a "freshwater" hookup port (like a garden hose) mounted on the hull somewhere? If so, I'd assume it might only work while you're hooked up to pressurized water (like at the dock).
    You're correct, the sink is a bladder bag setup.
    Drive Shower. scubydo Original Mariah Talk 4 08-16-2011 07:05 PM
    Transom Shower karmann Original Mariah Talk 1 06-03-2009 02:56 PM
    transom shower lance Original Mariah Talk 3 03-17-2009 06:56 AM
    Transom shower moondance100 Original Mariah Talk 4 09-06-2007 06:29 AM
    There are 208 users
