Drive Shower.
Old 08-12-2011, 01:51 AM   #1
scubydo is currently offline
My Model: 200
Send scubydo:
Default Drive Shower.
The top of my outdrive is chalky white, I've heard that if I put on a drive shower it will eliminate the cleanup. My boat only has the 4.3 V6 on a Alpha 1. any ideas.
  • Old 08-12-2011, 03:44 AM   #2
    Mariah350's Avatar
    Mariah350 is currently offline
    Send Mariah350:
    Default Re: Drive Shower.
    Yes, the drive shower can benefit any outdrive . When running at WOT or near it, the top of the drive is running out od the water and heats up. Once you pull back the throttle, the drive is submerged and what you see is the calcium resedue.
    One other tip is to run a good synthetic gear oil which will lower gear temps and in my case has lowered the amount of white calk stains.
    I know folks will debate syn motor oil but there is no debating Synthetic gear lubricant. I have been running my Alpha One for 15 years without one issue with Syn Gear lube. And the last 6 years with my 355 Perf SB high torque high RPM conditions
    Take Care All
    1995 Mariah Shabah 212 Z
    Performance Built 355 Vortec
    Alpha One Merc Laser II 21''
    GPS 64 Mph @ 5100 RPM
    Old 08-12-2011, 04:00 AM   #3
    Oregondunes's Avatar
    My Model: Z302 Bow Rider
    My Engine: 7.4 bravo3
    Gallery Images: 36
    Send Oregondunes:
    i have one and no longer have any white film. grease looked new after almost 100 hours
    check out the gallery pics, look in year 2000, oregondunes Z302, there you can see pics of mine
    2000 Z302 Bow Rider
    Old 08-12-2011, 05:58 PM   #4
    DFZ272 is currently offline
    My Model: Z272 Barchetta
    My Engine: 7.4 Bravo III
    Send DFZ272:
    Great idea with the synthetic gear lube.
    Dan
    Old 08-16-2011, 07:05 PM   #5
    Paul F's Avatar
    Paul F is currently offline
    Gallery Images: 4
    Send Paul F:
    I just realized that I'm not having that problem this year.
    Somebody take the minerals out of the water?
    Bravo 3 drive shower Oregondunes Mercury MerCruiser 4 04-13-2011 11:40 PM
    Transom Shower karmann Original Mariah Talk 1 06-03-2009 02:56 PM
    transom shower lance Original Mariah Talk 3 03-17-2009 06:56 AM
    Transom shower moondance100 Original Mariah Talk 4 09-06-2007 06:29 AM
    There are 258 users
