Odd Tach Problem
Old 02-09-2008, 10:50 PM   #1
sledge437 is currently offline
Send sledge437:
Default Odd Tach Problem
I have been experiencing an odd tach problem in my Talari. When idling and the idle RPM'S confirmed at 750, the tach shows 1200 rpms and continues to read about 500rpms oo high thru acceleration. I have checked the wiring to the tach and all the way back. I was hoping someone could send me in the right direction other than replacing the tach itself since I'd like to run the OEM so it matches all the other guages. Any help?
  • Old 02-10-2008, 01:15 AM   #2
    dwmax's Avatar
    dwmax is currently offline
    My Model: Shabah 212 Limited
    My Engine: 350 mag with alpha one
    Gallery Images: 17
    Send dwmax:
    Post
    I am not sure what kind of tach you have. But I was having a problem with mine and I sent it back to faria guages. They sent me a brand new guage exactly like the old one. they have a lifetime warranty and even if the guage is faulty due to your neglegence they will fix or replace it for 30 dollars which is a good deal. Also some of the guys here had a problem with there tach as well and said to turn the dial on the back of the tach with a small screwdriver a couple of times and then back to the original position because the contacts inside can get a little corroded try that first and let us know if that works.
    Darrell
    Old 02-10-2008, 03:38 AM   #3
    The tach is universal, for 4-6 & 8 cylinder engines. And there is a small turn dial on the back. If you take a small screwdriver and cycle through all the different settings a few times, then return it to the original setting, it'll clean the contacts, and chances are, your problem should be gone! It's usually a simple corrosion problem. It's a really common thing with Mariahs. But I can tell you, the turn dial trick worked for me!
    Old 04-29-2008, 04:49 AM   #4
    Send sledge437:
    Default Thanks!
    Sorry for the delayed response, but ya'll were right. I simply moved the cyclinder selector screw on the back of the boat back and forth a couple of times leaving it on 6 for my 4.3L and no more probs. Thanks all!
    Floor Drain Problem Douglas Alderman Original Mariah Talk 8 07-13-2010 01:45 PM
    Bad Tach/Compass WolfProperties Original Mariah Talk 6 05-05-2008 06:43 PM
    electrical problem nickc Sea Fox - Mariah Talk 4 02-24-2008 06:34 PM
    Name this Problem ShabahZ280 Original Mariah Talk 5 10-09-2007 01:41 PM
    Poss outdrive problem?? Jeff Barnett Original Mariah Talk 6 09-27-2007 10:02 AM
    There are 274 users
