Help Needed/Appreciated battery wires
Old 06-03-2012, 03:14 AM   #1
sstrawn1 is currently offline
My Model: Shabah 202
Send sstrawn1:
Cool Help Needed/Appreciated battery wires
Hey ya'll,
I have a 2000 Shabah 202 and am in the process of adding a second(house) battery. I have just about all the wires separated as to which ones go to the starting battery and the ones that will go to the house battery. I have come to 4 wires that are positive wires and i am not sure what they go to. They all have an inline fuse with a 5 amp fuse in each one. I have attempted to trace them but after so far, i lose sight of them. They are in a loom and run to the back of the boat and then back towards the front like towards the console area. I have checked all accessories that i can think of and so far everything works. Does anybody have a clue as to what these wires may be for? Thanks for your time.
  • Old 06-03-2012, 04:53 AM   #2
    csterner's Avatar
    csterner is currently offline
    My Model: Z275ST Shabah
    My Engine: 6.2L Bravo III
    Gallery Images: 9
    Send csterner:
    Default Re: Help Needed/Appreciated battery wires
    This might sound silly, but have you tried unplugging each positive connector one by one and seeing what doesn't work? That is what I have had to do in my boat...
    2001 Shabah Z275 ST
    6.2L Merc with Bravo III
    Old 06-03-2012, 09:14 AM   #3
    Brewfixer's Avatar
    My Model: Z222
    My Engine: 5.7
    Send Brewfixer:
    Ditto! Did the same on mine so I can find the hatch and bilge pump which should be the only ones you need hooked up directly to your battery.
    2001 Mariah Shabah Z222
    Old 06-03-2012, 04:27 PM   #4
    rayzorback's Avatar
    My Model: 210 LE
    My Engine: 454 Bravo 1
    Gallery Images: 10
    Send rayzorback:
    I just traced my wires also and if I remember correctly, One of the fused wired went to an unused 9 hole connector behind the throttle/shifter. I traced it with a "Tone" tracer. I could only see the connector by removing the stereo bezel and using a mirror ( I didn't want to remove the throttle). The other fused wire went to the automatic bilge pump (brown/grey?) I don't have a power hatch.
    Old 06-03-2012, 04:32 PM   #5
    Send sstrawn1:
    thanks guys, i have tried removing them one by one and so far everything on my dash toggle/accessories are working. I have not had the boat out on the water to verify if everything is working. 2 of the wires are red in color. They are not quite as thick as a speaker amp wire. 1 is a little smaller in diameter and is orange in color. The last one is slightly smaller and is brown with a white stripe if this helps anyone. Thanks again!
    Old 06-03-2012, 04:39 PM   #6
    rayzorback's Avatar
    My Model: 210 LE
    Gallery Images: 10
    Send rayzorback:
    Brown with white stripe is for the bilge pump. my orange was cut off so not sure what it is for (Help here anyone?). see my previous post on this thread for other fused red wire.
    Old 06-03-2012, 05:19 PM   #7
    Zackattack's Avatar
    My Engine: 5.7 Alpha 1
    Send Zackattack:
    were all these attached to the main power at your starter? Thats where is appears mine are linked(all four bolted on) at? Im grateful for your description since I too was wondering if I needed to separate these here and relocate them to the house battery side when I separate, but I think I will leave them so they are connected to the Engine battery instead.
    Zack
    1994 Z212 Shabah
    Old 06-03-2012, 06:59 PM   #8
    Send sstrawn1:
    Thanks guys,
    Rayzor, my bilge pump is working without these wires attached to the battery. I wouldn't have guessed that one of these wires would run to the throttle/selector switch. The throttle is cable operated correct? What would the wire be for?
    Zack, I have traced these 4 wires from the battery. They run into a wire loom to the back wall of the hull. They then run back up the starboard side and towards the driver console area, i assume. I can only see the wires for so long before losing sight of them.
    Old 06-03-2012, 08:05 PM   #9
    jarwiebe's Avatar
    jarwiebe is currently offline
    My Model: Z210 Shabah
    My Engine: 5.7 LX Alpha I
    Gallery Images: 2
    Send jarwiebe:
    Does your throttle/selector have the trailering tilt switch on it, if so then this live feed might be for it.
    Cheers
    Jake
    1996 Z210 Shabah
    Mercruiser 5.7LX
    Alpha One Drive
    80 Lb. SX Smart Tabs
    Old 06-03-2012, 10:32 PM   #10
    Send sstrawn1:
    yes, my throttle lever does have the trailer tilt switch on it. I just thought about that after going out to look again. thanks for the heads up.
    I didn't actually look at the back of the lever assembly. Do you know how many wires come from it. The 4 wires that i am talking about with
    the inline fuses do not look factory because the inluse fuse wire assemblies are not the same color and there are butt connectors.
    What are these wires? Steve91T Original Mariah Talk 11 08-24-2011 07:36 PM
    Finally appreciated? Phlorida Original Mariah Talk 1 08-01-2011 11:59 PM
    Well, Welcome and help needed! Mike S Original Mariah Talk 8 02-24-2011 06:31 PM
    3.0l LX cant figure out what wires are. pimpadelic Mercury MerCruiser 3 07-22-2009 12:40 AM
    There are 337 users
