Help Needed/Appreciated battery wires
Old 06-04-2012, 02:17 AM   #11
rayzorback's Avatar
My Model: 210 LE
My Engine: 454 Bravo 1
Gallery Images: 10
Send rayzorback:
Default Re: Help Needed/Appreciated battery wires
Originally Posted by sstrawn1 View Post
yes, my throttle lever does have the trailer tilt switch on it. I just thought about that after going out to look again. thanks for the heads up.
I didn't actually look at the back of the lever assembly. Do you know how many wires come from it. The 4 wires that i am talking about with
the inline fuses do not look factory because the inluse fuse wire assemblies are not the same color and there are butt connectors.
The connecor behind the throttle has no male end connected to it... It dead ends at the female connector. I could only see it with a mirror through the hole after removing the stereo bezel. My 4 wires didn'tlook factory either. One (Brown/White) went to the bilge pump, the other to the unused connector behind the throttle. There are 4 wires on the starter also which I thought was incorrect, but turns out some jumped to the battery there. I replaced the alternater wire with one to an Isolator for a two battery system to keep them both charged. Hope this helps you can call me at 479-221-6827 if you want.
Ron
    What are these wires? Steve91T Original Mariah Talk 11 08-24-2011 07:36 PM
    Finally appreciated? Phlorida Original Mariah Talk 1 08-01-2011 11:59 PM
    Well, Welcome and help needed! Mike S Original Mariah Talk 8 02-24-2011 06:31 PM
    3.0l LX cant figure out what wires are. pimpadelic Mercury MerCruiser 3 07-22-2009 12:40 AM
    There are 338 users
