Shabah 18 factory bilge pump location question
Old 05-05-2012, 02:12 PM   #1
eroc37 is currently offline
My Model: shabah
My Engine: 4.3 Alpha II
Send eroc37:
Default Shabah 18 factory bilge pump location question
there seems to be a square raised pad in the sole of the boat just under the front of the 4.3 engine. i can almost see screw holes in it... was this the factory pad placed under the fiberglss to mount the bilge pump?
my boat has a small, non float switched, bilge pump screwed to the bulkhead that divides the motor compartment and the gas tank compartment. i am replacing the pump with one that has a float switch, and is a larger size.
Before i create an angle bracket to mount this pump (it attaches on the bottom) i would love to know if that raised pad is designed to be the base of the factory bilge pump.
anyone know?
  • Old 05-05-2012, 03:32 PM   #2
    Default Re: Shabah 18 factory bilge pump location question
    I dont have my boat handy but i'm pretty sure that is where mine is mounted.
    Old 05-05-2012, 07:32 PM   #3
    My Model: shabah
    Send eroc37:
    Yep; makes sense to me!
    thanks!
    Old 05-05-2012, 10:25 PM   #4
    jarwiebe's Avatar
    jarwiebe is currently offline
    My Model: Z210 Shabah
    My Engine: 5.7 LX Alpha I
    Gallery Images: 2
    Send jarwiebe:
    The bilge pump in my Z210 is mounted on the pad as you described it.
    Cheers
    Jake
    1996 Z210 Shabah
    Mercruiser 5.7LX
    Alpha One Drive
    80 Lb. SX Smart Tabs
    Bilge pump fuse location Jess Bembry Original Mariah Talk 4 06-26-2011 05:34 PM
    Bilge Pump ROMFORD_NAVY Sea Fox - Mariah Talk 2 06-03-2011 01:22 PM
    Z192 Factory Console Plate Replacement/Switch Location? jkboliphant Original Mariah Talk 7 09-23-2010 11:55 AM
    Bilge pump question nglauer Original Mariah Talk 7 07-27-2010 01:44 AM
    Bilge pump andyc Sea Fox - Mariah Talk 7 07-14-2009 04:01 PM
    There are 372 users
