Bilge pump fuse location
Old 05-05-2009, 02:15 AM   #1
Jess Bembry is currently offline
Send Jess Bembry:
Default Bilge pump fuse location
I have a 1999 Jubilee 21 ft deck boat with a 7.4L engine. I'm in the process of replacing the bilge pump. When the old pump went it blew the fuse that powers the rocker switch and I'm having trouble locatin the fuse. Any ideas?
  • Old 05-05-2009, 09:33 AM   #2
    Default Re: Bilge pump fuse location
    Hi Jess,
    Have you looked under your dash? Many Mariahs have a fuse panel up under the dash and a breaker panel near the driver or possibly in the enclosed head compartment.
    Try tracing the leads from the switch as you may also have an inline fuse there as well.
    Good luck and let us know where you find it,
    Old 05-05-2009, 07:22 PM   #3
    stereoman405's Avatar
    Send stereoman405:
    My boat came with a OEM dual battery switch and had the bilge fuse located right off of the switch itself. A lot of these boats had an automatic bilge, so even if you don't have the dual batt switch, it might be wired directly to your battery . (Comes on regardless of rocker position.) It was a brown wire with a white stripe on mine.
    HTH.
    Link to Photos!
    Old 05-06-2009, 10:33 AM   #4
    Hi Jess,
    Glad I was able to help!
    Old 06-26-2011, 05:34 PM   #5
    jp887 is currently offline
    My Model: 2200 zc
    My Engine: 305 cubic inch, Alpha
    Send jp887:
    Did anyone find the location of this bilge pump fuse? Mine's blown, and I'm still hunting. (94 2200zc)
    - Jim
    Bilge pump issue adornare Original Mariah Talk 12 03-29-2010 03:30 AM
    Auto bilge pump flattened battery Mayal Sea Fox - Mariah Talk 10 07-20-2009 07:58 AM
    1998 Z252 Auto bilge pump replacement edward cossey Original Mariah Talk 2 06-09-2008 06:41 PM
    There are 249 users
