up trim not working
Old 06-12-2011, 03:19 AM   #1
michaelb is currently offline
My Model: Talari 22
My Engine: 5.7 lt Brava I
Send michaelb:
Default up trim not working
My up trim stopped working, I was able to raise the outdrive by crossing the wires at the pump. since then I found damaged wires leading to the trim switches on the outdrive and managed to repair these wires. Now I get a clicking sound when I push the up trim switch, my batteries are good and all connections are clean on the trim pump. Any ideas?
thanks
  • Old 06-12-2011, 11:10 PM   #2
    My Model: Talari 22
    Send michaelb:
    Default Re: up trim not working
    I have it fixed, 2 things were wrong at the same time, I had damaged wires at the outdriive leading to the trim switch and I had a bad solenoid at the trim motor.
    Old 06-13-2011, 12:42 AM   #3
    Glad to hear you found the problem quickly & it was a relatively easy repair!
    New transom assembly now trim up not working grommett Original Mariah Talk 5 03-26-2011 06:30 PM
    mariah sx19 mercruiser alpha trim up trim gauge bad mrtransistor Mercury MerCruiser 1 08-05-2010 03:37 AM
    Trim Tab not working. john elbro General Maintenance 4 07-28-2009 01:39 AM
    Non working trim switch River Man Original Mariah Talk 3 07-20-2009 05:19 PM
    There are 435 users
