location of oil drain plug
Old 09-19-2011, 03:26 PM   #1
nana is currently offline
My Model: shabaz 202
My Engine: 4.3 alpha 1 mercruiser
Send nana:
Default location of oil drain plug
we have a 98 shabaz 202 and want to change the oil. does it have a drain plug and if so where is it located? Or do you need a pump?
  • Old 09-19-2011, 03:55 PM   #2
    mosky's Avatar
    mosky is currently offline
    My Model: 202
    My Engine: 5.0L Alpha
    Send mosky:
    Default Re: location of oil drain plug
    If i remeber correctly the drain plug should be near the back of the oil pan either on the side or right on the bottom. do yourself a huge favour and invest in an oil drain hose kit. This will replace you oem drain plug and come with a 4' or so long hose. When it's time to change the oil just fish the hose out your transom drain plug and into a container to collect the old oil and open the plug and let it drain while you tend to something else. No more mess in the bilge! If you do your own oil changes it is $30 very well spent. Here's a link to a sample one but make sure that the threads are the same size as you have on your engine:
    Overton's® > Oil Drain Kit - 3/8 x 18 Thread Size - Boating & Marine > Maintenance > Oil Changers & Filters : Boat Maintenance Products, Marine Supplies, Repair Kits, Accessories
    Thank you mosky for this useful post!
    mikeyt (09-19-2011)
    No plug rooperdan Boating 101 9 07-26-2011 05:51 PM
    Oil plug???? jeffro788 Original Mariah Talk 11 08-26-2010 12:15 PM
    exhaust manifold drain plug broken Javier Hernandez Mercury MerCruiser 2 05-31-2010 12:58 PM
    Oil plug help Marci Sadler Introductions 3 05-16-2010 10:20 PM
    Ski well drain/bilge drain jhaag41 General Maintenance 1 07-17-2008 10:09 PM
    There are 238 users
