new engine, no power
Old 08-21-2011, 10:01 AM   #1
ridnwild is currently offline
My Engine: 5.7 bravo III
Send ridnwild:
Default new engine, no power
I finally got my boat out of the shop yesterday (new engine, water pump, gimbal ring assembly, etc.), took it to the lake for its first run on new 300hp engine. No power on takeoff, bogging bad, will not pull a skier, just barley plane, if trim is up just a little it will not plane.
Shop is not open till monday, Would like to fix it today. Any suggestions?
1995 Talari 240 350MPI BravoIII
  • Old 08-21-2011, 01:45 PM   #2
    rooperdan's Avatar
    rooperdan is currently offline
    My Model: 1998 SHABAH 210
    My Engine: Built 350 Alpha Drive
    Gallery Images: 10
    Send rooperdan:
    Default Re: new engine, no power
    Sounds like timing issue. or your plug- wires could be placed wrong. Just a thought.
    Quietly Making Noise
    Old 08-21-2011, 03:39 PM   #3
    Send ridnwild:
    Yes thats what I think or maybe bad gas. I put 50 gal of fresh gas in it, it already had some gas in it but that did not fill it up. I'm leaning more toward timing, it runs fine, it just boggs under load.
    Old 08-22-2011, 03:07 AM   #4
    DFZ272 is currently offline
    My Model: Z272 Barchetta
    My Engine: 7.4 Bravo III
    Send DFZ272:
    I agree, most likely timing issue. Call the shop and let them know. I would not mess with it too much myself since you just got it back. Make them earn their money. Good luck
    Happy Boating
    Dan
    1995 Z272 Barchetta
    Old 08-22-2011, 07:06 AM   #5
    Send ridnwild:
    Yes. I decided not to screw with it. Don't want to void the warranty.
    Old 08-31-2011, 05:36 PM   #6
    Dredd's Avatar
    Dredd is currently offline
    My Model: MX-19 - Sold
    Send Dredd:
    What came of this?
    Old 08-31-2011, 10:07 PM   #7
    Send ridnwild:
    Just got it back. They said the timing was way out. Can't try it till saterday.
    Old 08-31-2011, 10:36 PM   #8
    darkcalling's Avatar
    My Model: Z278 Limited
    My Engine: 502 Bravo III
    Gallery Images: 3
    Send darkcalling:
    Bet it was the old 180 degree off. Done that a couple times myself lol.
    darkcalling
    Z 278 Limited
    Old 09-01-2011, 12:34 AM   #9
    Send ridnwild:
    Still not sure its fixed though. He said he couldn't get it to rev up in the pit, but sometimes that happends with bigger boats and dual props (never heard that before). He said try it out & bring it back if still not right.
    Old 09-04-2011, 01:28 AM   #10
    Send ridnwild:
    Nope didn't fix it. It ran a lot better at first, but then it started knocking & bogging then back firing. It never died but I pulled it back before it did. Tried again same thing. I went ahead and ran it like this just to see if it was bad gas (I put in two cans of seafoam & filled it up) but after about an hour and a half that was enough. On the way back it started missing too a couple times it started to pick up but then fall on its face again. Back to the shop!
    Power engine cover/hatch NogginDoc Boating 101 1 07-19-2010 07:17 PM
    Power engine hatch cover pics karmann Original Mariah Talk 0 05-09-2009 02:36 AM
    Problem w/ power engine cover joe2106 Original Mariah Talk 6 12-28-2007 04:12 PM
    Power ram for engine cover 97 Z222 Original Mariah Talk 2 11-12-2007 09:56 PM
    There are 314 users
