Fuel pressure?
Old 08-08-2011, 02:52 PM   #1
42hut is currently offline
Send 42hut:
Default Fuel pressure?
Has anyone ever had too much fuel pressure in a carbed boat?
93 Z2350...big block...14 psi at 2200 rpm.
  • Old 08-09-2011, 01:16 AM   #2
    Hudson River Steve's Avatar
    My Model: Z280
    My Engine: 7.4L MPI Bravo3
    Send Hudson River Steve:
    Default Re: Fuel pressure?
    Mechanical fuel pumps usually top out at less than 10 psi...and usually much lower than that. You need to check the specs on your carb to determine the optimum pressure, probably around 6 psi. Too much pressure and your float needle valve will be unable to seat and you will run rich and most likely stall at idle.
    Hudson River Steve
    1999 Z280
    7.4 MPI, Bravo3
    Old 08-09-2011, 01:29 AM   #3
    Send 42hut:
    Yes, I know....but why is the original pump pumping too much.....usually they pump too little when they fail?
    Just wondering why.
    Too much fuel pressure? 42hut Mercury MerCruiser 4 08-08-2011 07:46 PM
    Oil Pressure andyc Mercury MerCruiser 4 06-22-2011 08:20 PM
    losing fuel pressure D_Man Mercury MerCruiser 0 07-17-2010 07:39 PM
    losing fuel pressure D_Man Original Mariah Talk 0 07-17-2010 05:30 PM
    Oil Pressure my97camaro General Maintenance 0 06-15-2010 03:11 PM
    There are 389 users
