Question about Blower / Horm
Old 08-03-2011, 04:15 AM   #1
mikesull415 is currently offline
Send mikesull415:
Default Question about Blower / Horm
Hey guys, sorry I haven't been around in a while...but with this 100+ degree weather we've been having everyday over the past three weeks I've been trying to stay on/in the water as much as possibly. Got a problem though. My blower is not working. The switch is still lighting up, which I don't know if that matters or not, but I'm getting nothing from the blower at all. It started slowly....sometimes it came on fine, then it wouldn't, then it would....and no nothing. I'm hoping something's jus loose or a blown fuse or something but have no idea where to start.
Just found out today that the horn isn't working either. Worked fine when we got the boat.....but no more.
SO......any ideas?
  • Old 08-03-2011, 04:33 AM   #2
    KeepitReal is currently offline
    My Model: Diablo 180
    My Engine: 4.3 Mercruiser
    Send KeepitReal:
    Default Re: Question about Blower / Horm
    1st check would always be fuses. After that since you're crawled up under the dash anyway, use a test light and see if you have power on both sides of the switch when it's turned on. If power is making its way through the switch, check for power directly at the motor. If you have power all the way to the motor, looks like the motor is out. The only other thing to double check is a good ground to the motor which can be checked with a simple ohmmeter or by reversing the test light lead to check for a ground.
    blower and Nav light 2006 red sx 20 Sea Fox - Mariah Talk 0 06-09-2011 01:46 AM
    Z275 Bilge Blower question csterner Mercury MerCruiser 8 04-14-2011 01:46 AM
    blower switch z71forme Mercury MerCruiser 8 03-28-2011 08:13 PM
    shabah question - blower ATI WS6 Original Mariah Talk 10 08-24-2009 03:34 AM
    Blower Not Working!!?? toddneedham Original Mariah Talk 12 07-31-2009 02:34 PM
    There are 363 users
