acceleration problem
Old 07-21-2011, 11:24 AM   #1
mancem is currently offline
My Model: z2240 talari
My Engine: 7.4 bravoIII
Send mancem:
Default acceleration problem
I own a 1995 Talari 7.4 BravoIII that has been giving me intermediate acceleration problems for approximately 3years. When I hit the accelerator I get a hestitation that last a few seconds then the boat runs normal. I have had a tune with new wires, plugs, cap, and my carb gone thru by my mechanic who states that he thinks it might be a vapor leak. I think it started when the ethanol was added to the gas and am wondering if anyone has had the same problem? I am looking for any suggestions that I have not thought of.
Mancem
  • Old 07-21-2011, 12:26 PM   #2
    rooperdan's Avatar
    rooperdan is currently offline
    My Model: 1998 SHABAH 210
    My Engine: Built 350 Alpha Drive
    Gallery Images: 10
    Send rooperdan:
    Default Re: acceleration problem
    If your engine is carburated it could be your acceleration pump at your carb.
    Quietly Making Noise
    Thank you rooperdan for this useful post!
    mancem (07-21-2011)
    Old 07-21-2011, 01:59 PM   #3
    Send mancem:
    thanks the carb has been checked and is operating properly
    Old 07-21-2011, 07:51 PM   #4
    Zackattack's Avatar
    My Engine: 5.7 Alpha 1
    Send Zackattack:
    I feel the ethonal is a bigger problem than people realize. I am on my first tank of ethenal free fuel now. Have not yet ran it, but all the marinas here are now refusing the ethanol and will be serving up ethanol free fuel.
    Find a source, and try it. Thats what I have decided. And change the filter.
    Zack
    1994 Z212 Shabah
    Old 07-21-2011, 10:02 PM   #5
    Slash9point5's Avatar
    My Model: Barchetta 182
    Send Slash9point5:
    Sta-bil makes a marine version that claims to have a method to prevent against the effects of ethanol addative in fuels.
    I have used it for the past year and a half of boating and have not had any issues using mostly 89 octane but occasionally 87 octane (both containing 10% ethanol).
    Here is a seller on amazon that also lists some info about the problem and its protection method, but I picked up the 32oz bottle for $19.99 at Gander Mountain. The 32oz bottle is a much better deal.
    Amazon.com: STA-BIL 22239 Marine Fuel Stabilizer - 8 Fl oz.: Automotive
    I'll probably continue to use this product unless I experience fuel related problems as it is roughly $0.06/gallon extra compared to $0.15 to $0.20 extra for non-oxygenated. So, it is saving about $60 gross and $40 net per 32oz bottle (320 gallons of treatment).
    Kris
    Old 07-22-2011, 01:26 AM   #6
    Shabah 198SE's Avatar
    Shabah 198SE is currently offline
    My Model: Shabah 198SE
    My Engine: 5.7L Alpha
    Send Shabah 198SE:
    mancem,
    I agree with rooperdan. It sounds like a fuel/accelerator pump problem. Just because the carb was done doesn't mean that it was set up correctly.
    Shabah 198SE
    Old 07-22-2011, 11:21 PM   #7
    SEMIJim's Avatar
    SEMIJim is currently offline
    My Model: 182 Barchetta
    Send SEMIJim:
    Regardless of what you've been told: Your symptoms fit perfectly those of an accelerator pump problem. If you don't know what to look for in the carburetor, yourself, I suggest getting a second opinion from a qualified mechanic.
    As I've noted many times before here: When you first open the throttle on a carbureted engine, more air starts flowing faster than more fuel, so the engine leans-out badly. This results in hesitation, or even stalling. The accelerator pump is something that's activated when the accelerator is depressed, and squirts an off-setting amount of fuel into the carb throats. Accelerator pumps wear out.
    There is one other possibility--I think. But, not being familiar with your engine, I wouldn't begin to know where you should look. That other possibility is a malfunction in the automatic spark advance/retard mechanism/system. See here: Popular Mechanics - Google Books for a description on how they (used to?) work and what they do.
    Good luck,
    Jim
    “The bitterness of poor quality is remembered long after the sweetness of low price has faded from memory.” - Aldo Gucci
    Click Here --> Help Support The Mariah Owner's Club <-- Click Here!
    Old 08-03-2011, 04:52 AM   #8
    KeepitReal is currently offline
    My Model: Diablo 180
    My Engine: 4.3 Mercruiser
    Send KeepitReal:
    I had a similar problem with my 4.3 that turned out to be ignition timing out of adjustment. Momentary sputtering and hesitation on acceleration before it would pick up and go. I think my case was somewhat extreme. My timing had been set at 2 degrees ATDC when it should have been 8 degrees BTDC. Adjusted the timing and she ran like a beast
    Old 08-03-2011, 06:23 PM   #9
    DFZ272 is currently offline
    My Model: Z272 Barchetta
    My Engine: 7.4 Bravo III
    Send DFZ272:
    Quick accelerator pump test. After engine has been started once and the carb is full of fuel. Turn off the motor, remove the flame arrestor on top of the engine. Look inside the front throat of the carb(U made need a flashlight), then have a friend quickly advance the throttle a couple of times while u observe, if the pump is working you should see and hear fuel squirt into the front throat of the carb. If it doesn't the pump is bad. NOTE: U must be sure the carb is full of fuel for this test to work and don't do it too many times or u will flood the engine.
    Hope this helps
    Dan
    Old 08-03-2011, 07:00 PM   #10
    Dredd's Avatar
    Dredd is currently offline
    My Model: MX-19 - Sold
    Send Dredd:
    Good suggestion.
    I worked on a boat last Spring that had an issue similar to this. I could adjust the carb and move the dead spot up or down in the RPM range but never could get it to go clear away, especially under a load. A timing adjustment finally fixed it up right.
    mercruiser 5.7 problem Brownboy Boating 101 3 10-13-2010 04:03 AM
    Starting Problem mark shumaker Original Mariah Talk 7 09-08-2009 11:03 PM
    Prop problem? curtis Prop Talk 4 06-15-2009 12:23 AM
    bad problem dmg5606 Mercury MerCruiser 3 06-03-2009 12:20 AM
    Name this Problem ShabahZ280 Original Mariah Talk 5 10-09-2007 01:41 PM
    There are 314 users
