4.3 LX Fuel Pump
Old 08-19-2011, 03:08 PM   #21
Zackattack's Avatar
My Engine: 5.7 Alpha 1
Send Zackattack:
Default Re: 4.3 LX Fuel Pump
Originally Posted by KelRem View Post
I've already checked the fuel filter, I think it's fine,
Replace it, how do you have confidence in checking it?
Zack
1994 Z212 Shabah
  • Old 08-19-2011, 04:05 PM   #22
    KelRem is currently offline
    My Model: Shabah 18
    My Engine: 4.3L LX Alpha One
    Send KelRem:
    I figure it's fine, because the only issue with the boat is cold starting. And a momentary loss of power when pushing the power up. Other than that it runs fine all day. If there was an issue with the fuel filter I would suspect there would be issues running the boat wide open which there isn't.
    Old 08-19-2011, 07:41 PM   #23
    shonuff93 is currently offline
    My Model: mx 19
    My Engine: 4.3 v6
    Send shonuff93:
    Napa sells a rebuild kit for around $40 and the only thing you would need is a gasket from the carb to manifold ($5). There are 2 filters where the fuel line meets the carb. 1 on each side that filter before it fills up the bowls. My filter on the opposite side of the fuel line was nasty! water also got in there and formed some rust on the primaries and secondaries. This kit (Napa 2-5763A) came with everything but the right gasket I stated above, even comes with the acc pump. It will save you about $100 or so.
    Good Luck!
    Old 08-22-2011, 06:13 PM   #24
    My Model: Shabah 18
    Send KelRem:
    Ok, I should have tried this before ordering the carb kit, oh well. I took off the fuel line from the fuel pump and checked to see if any fuel was flowing from it when cranking the engine. Nothing is coming from the fuel pump while cranking. Took the electrical connector off the pump and cranked engine again. Shows about 9-10 volts at the connector. Tried connecting the fuel pump directly to the battery (with alligator clips) and a steady stream of gas comes out . Tried connecting the electrical plug for the fuel pump again and no fuel coming out. Still shows about 10 Volts at the connector though... So what are the chances there is something wrong with the electrical connector? Maybe it's not making a good contact with the connector on the pump itself.... Anyone?
    Old 08-23-2011, 12:55 AM   #25
    DFZ272 is currently offline
    My Model: Z272 Barchetta
    My Engine: 7.4 Bravo III
    Send DFZ272:
    You will have some voltage drop when cranking just from the drag of the starter. If the motor spins fine it could be a bad connection from the starter to the pump wire, a bad pump wire, or something internal to the starter solenoid. I would make sure all of the connections are clean. I don't think a 2 volt drop should be enough to prevent the pump from filling the carb though. These dang boats can be aggravating can't they. Let me know what you find out.
    Happy Boating
    Dan
    1995 Z272 Barchetta
    Old 08-23-2011, 01:00 AM   #26
    My Model: Shabah 18
    Send KelRem:
    When I get back home, I'll check to make sure all the connections are clean. I'm thinking it's the plug that goes into the pump that is the issue. Maybe it's not making good contact with the pins receptacles in the pump...
    Fuel Pump Problem on 4.3 Y-Knot Mercury MerCruiser 3 10-18-2010 12:59 AM
    Is this the fuel pump ? shoup2010 Mercury MerCruiser 6 07-11-2010 02:24 PM
    fuel pump help pls fl_bill Original Mariah Talk 9 07-03-2010 02:25 AM
    Fuel pump issues. jetscat7 Original Mariah Talk 4 05-09-2010 06:40 PM
    looking for fuel pump urim Original Mariah Talk 0 01-18-2010 12:25 AM
    There are 354 users
