Fuel Pump Problem on 4.3
Old 10-16-2010, 07:10 PM   #1
Y-Knot's Avatar
Y-Knot is currently offline
My Model: 2009 FS-18 4.3 Mercruiser Alpha I
Send Y-Knot:
Default Fuel Pump Problem on 4.3
Hey all,
Just getting at winterizing my 4.3 carburated V-6 and am having problems.
Starts fine and runs until out of fuel, say 45 seconds at idle. Hit the starter and runs fine again until out of fuel. This all new after sitting about a month on the trailer, ran like a champ all season.
I've changed the fuel filter and there is sufficient fuel on board. I loosened the fuel line at the carb and rolled her over, lots of fuel squirting while rolling over.
Tighten line and start, loosen fuel line while it's running and it's dry, nothing, nadda.
If I recall, GM likes to control fuel pumps with the oil pressure sensor. Could this be the problem? I changed the oil filter and it acts the same regardless.
I did trace the fuel pump electrical leads to a brown electrical device shaped like a disposable lighter with a diode symbol (I think). Pulled the device out of circuit and it ran the same. If I disconnect the fuel pump leads won't start at all (this I would expect).
Anybody have an idea?
Cheers,
Y
2009 FS-18, 4.3 Alpha 1
  • Old 10-17-2010, 04:27 PM   #2
    Y-Knot's Avatar
    Send Y-Knot:
    Default Re: Fuel Pump Problem on 4.3
    Fugetaboutit,
    Oil pressure switch.
    Anybody know of a generic replacement switch part number? I'm sure the Quicksilver unit is astronomical $.
    Cheers,
    Y
    Old 10-17-2010, 06:28 PM   #3
    Originally Posted by Y-Knot View Post
    Fugetaboutit,
    Cheers,
    Y
    Try these...?
    Universal is $17. at iboats.com
    Quicksilver is $28.70 at Go2Marine.com
    Old 10-18-2010, 12:59 AM   #4
    Y-Knot's Avatar
    Send Y-Knot:
    Niether of those are gonna work for a direct replacement.
    May have to be a visit to the shop after all...........
    Cheers,
    Y
    Is this the fuel pump ? shoup2010 Mercury MerCruiser 6 07-11-2010 02:24 PM
    fuel pump help pls fl_bill Original Mariah Talk 9 07-03-2010 02:25 AM
    looking for fuel pump urim Original Mariah Talk 0 01-18-2010 12:25 AM
    Problem with non-OEM water pump impellers Talari240ZinAZ General Maintenance 1 06-15-2009 09:56 PM
    new bildge pump problem pimpadelic Original Mariah Talk 7 05-31-2009 06:05 AM
    There are 263 users
