Is this the fuel pump ?
Old 07-11-2010, 12:20 AM   #1
shoup2010 is currently offline
My Model: TALARI Z240
My Engine: 7.4 l
Send shoup2010:
Default Is this the fuel pump ?
I have a 1996 Talari 7.3L. It is making a grinding noise at 2000 rpm from what looks like the fuel pump. Does anyone know where I can order a replacement pump or have a part number for this ? I snapped a couple of pictures. I'm not to good with a digital camera though. Thanks!-John
  • Old 07-11-2010, 12:41 AM   #2
    jgreen's Avatar
    jgreen is currently offline
    Gallery Images: 2
    Send jgreen:
    Default Re: Is this the fuel pump ?
    H John, I believe what you're looking at is the combination fuel pump and sea water pump. When was the last time you had the impeller changed?
    Jay
    Old 07-11-2010, 01:40 AM   #3
    My Engine: 7.4 l
    Send shoup2010:
    Thanks for the reply! I believe it was 2 years ago I had the impellar replaced.
    Old 07-11-2010, 03:02 AM   #4
    jgreen's Avatar
    Gallery Images: 2
    Send jgreen:
    The impeller shouldn't be making any grinding noise, but you might want to give a listen to the front nose bearing in the pump housing.
    Jay
    Old 07-11-2010, 05:02 AM   #5
    My Engine: 7.4 l
    Send shoup2010:
    It definatelu sound like a bad bearing. Do you have any expieeienxe changing the bearing. I assume you have to replace the pump and not just the bearing.
    Old 07-11-2010, 05:30 AM   #6
    jgreen's Avatar
    Gallery Images: 2
    Send jgreen:
    Nope I never had to get into the front of the pump, but it is repairable. The manual is on here. Doesn't look too bad. Good luck.
    Jay
    Old 07-11-2010, 02:24 PM   #7
    My Engine: 7.4 l
    Send shoup2010:
    Thanks for your help! -John
    fuel pump help pls fl_bill Original Mariah Talk 9 07-03-2010 02:25 AM
    How to replace a fuel pump filter?? CARL SWINDLE General Maintenance 0 05-29-2010 03:03 AM
    Buzzer and fuel pump chadh45701 General Maintenance 2 05-22-2010 07:53 PM
    Fuel pump issues. jetscat7 Original Mariah Talk 4 05-09-2010 06:40 PM
    looking for fuel pump urim Original Mariah Talk 0 01-18-2010 12:25 AM
    There are 276 users
