How lift engine cover with dead battery
Old 04-20-2011, 02:16 PM   #1
Mike Cook is currently offline
My Model: z216 talari
My Engine: 350
Send Mike Cook:
Default How lift engine cover with dead battery
The battery is dead dead and it has a elect. lift how do I get it up to get the battery out? Just purchase boat its z216 tal.
  • Old 04-20-2011, 03:20 PM   #2
    rajjneef's Avatar
    rajjneef is currently offline
    My Year: 97'
    My Model: Z242 Shabah
    My Engine: 350 efi Bravo III
    Gallery Images: 3
    Send rajjneef:
    Default Re: How lift engine cover with dead battery
    Have someone help you and try lifting the hatch up just enough to pull the bench seat down. Then you can pull the pin on the lift. If you have real small arms you might be able to get to the pin without pulling the bench seat down.
    Thank you rajjneef for this useful post!
    Mike Cook (04-21-2011)
    Old 04-21-2011, 06:19 PM   #3
    Oregondunes's Avatar
    My Model: Z302 Bow Rider
    My Engine: 7.4 bravo3
    Gallery Images: 36
    Send Oregondunes:
    On my z302 you can lift the hatch about 4 inches, enough to get your hand/arm inside to pull the hatch pin
    2000 Z302 Bow Rider
    Thank you Oregondunes for this useful post!
    Mike Cook (04-26-2011)
    Old 04-23-2011, 04:48 AM   #4
    Zackattack's Avatar
    My Engine: 5.7 Alpha 1
    Send Zackattack:
    You could backfeed the 12 V system with a charger through the cig. lighter adapter.???? Just an idea.
    Zack
    1994 Z212 Shabah
    Old 04-26-2011, 01:24 AM   #5
    My Engine: 350
    Send Mike Cook:
    Thanks to everyone who had a great ideas got the problem fix still need to get her to Florida now.
    Old 04-26-2011, 02:31 PM   #6
    Zackattack's Avatar
    Send Zackattack:
    So, how were you able to do it?
    Zack
    1994 Z212 Shabah
    Old 04-26-2011, 05:26 PM   #7
    My Engine: 350
    Send Mike Cook:
    Well as bad that I have to say it. It didn' have a lift on I was lifting the wrong way. I read where somone said that all z models had the elect. lift. So that's not true this just pull out front front.
    Old 04-26-2011, 07:40 PM   #8
    Zackattack's Avatar
    Send Zackattack:
    You are to be congradulated for admiting that. I thought all the Z's would have had it too, now ya know.
    Zack
    1994 Z212 Shabah
    Thank you Zackattack for this useful post!
    Old 04-27-2011, 03:08 AM   #9
    it might have been removed by the previous owner, at least mine was... wiring's still there, and so are the screw holes where the actuator was mounted.
    maybe someday i'll get around to replacing it, and i'll definitely be adding a remote jump port in case of battery failure. my friend's rinker 342 had one and it definitely made it much easier to get the hatch up in the wintertime with a jump box.
    Mike Cook (04-27-2011)
    Help! Need info on Engine Hatch Lift - Z302 milemarker60 Original Mariah Talk 6 07-13-2022 10:58 AM
    engine cover automatic lift rod for a 1993 2350z erndog123 Original Mariah Talk 1 08-05-2010 11:44 AM
    Sun Deck / Engine Cover Acadianbasic Original Mariah Talk 6 06-01-2008 01:14 PM
    Power ram for engine cover 97 Z222 Original Mariah Talk 2 11-12-2007 09:56 PM
    96 talari Z240 Engine Hatch Lift Help WetWilly Original Mariah Talk 8 10-02-2007 12:30 PM
    There are 250 users
