Throttle Question
Old 04-18-2011, 01:20 PM   #1
RichB is currently offline
Send RichB:
Default Throttle Question
Hi Chaps
Slightly odd question for here I guess, but here goes...
I'm running my 180Shabah on a river with a pretty harsh speed limit. Wondering if there is any adjustments that I can make to the throttle to make it more easily adjustable between tickover and tickover + a bit. Basically need to keep the speed under 12 knots or so.
I think it is the standard quicksilver throttle controller, and the modification would need to be something that could be undone reasonably easily - eg for when I do get out of the speedlimit zone!
Any ideas?
  • Old 04-19-2011, 04:14 PM   #2
    al levy is currently offline
    My Model: 272 shabah
    My Engine: 7.4 bravo 111
    Send al levy:
    Default Re: Throttle Question
    there might be a tension screw somewhere on the control. are you planning on keeping the boat? if so and there is a flat surface near the control you could think about putting zero effort controls in that can usually be bought cheap on ebay. i know its a smaller boat but by any chance do you have hydraulic trim tabs?
    Throttle question theeasynine Mercury MerCruiser 1 04-15-2011 10:26 PM
    Throttle handle roger simkin Mercury MerCruiser 1 01-01-2010 09:40 AM
    Throttle Arm assembly? trussman Original Mariah Talk 1 07-07-2009 12:08 PM
    Throttle Control Shifter Question? Douglas Alderman Original Mariah Talk 21 06-25-2009 07:44 PM
    Throttle and shifter question.. Jeff Barnett Original Mariah Talk 3 09-19-2007 12:30 AM
    There are 365 users
