Transom Wet Storage Leak
Old 03-29-2011, 12:56 PM   #1
mark43 is currently offline
My Model: Z210 Shabah
My Engine: 5.7L Bravo III
Send mark43:
Default Transom Wet Storage Leak
Hi Everyone,
Last fall after pulling my 1998 Z210 from the water, I noticed water draining out around the brass sleeve in the transom wet storage locker even though the locker was dry. Upon further inspection, I noted that the bras drain sleeve was loose and that the water was actually leaking from the space between the wet storage bottom and outer fiberglass shell. It also appeared that there was a decent size cavity that runs across that back of the boat above the outdrive that also had water in it. I went ahead and pumped out all of the water that I could using a vacuum pump. I ended up pulling about a gallon or so out of the void. I have since sealed the brass drain sleeve so water will not be entering the void anymore, but I am wondering if anyone else has had this issue or know whether or not my transom is at any risk. It appeared that the void the water got into was a sealed off, but any thoughts would be appreciated.
Thanks!
  • Old 03-30-2011, 01:28 AM   #2
    rooperdan's Avatar
    rooperdan is currently offline
    My Model: 1998 SHABAH 210
    My Engine: Built 350 Alpha Drive
    Gallery Images: 10
    Send rooperdan:
    Default Re: Transom Wet Storage Leak
    Hey, I had the same thing happen to our 98 210. after spending around 800 dollars on everything else we thought it could be, we realized that it was from the drain plug sleeve at the rear cooler, which had a worm-hiole down threw the transom to the drain plug.
    Quietly Making Noise
    Old 03-30-2011, 02:43 AM   #3
    Send mark43:
    I am sorry to hear that you ended up spending so much on what amounted to be a simple issue....I actually talked to a dealership that sold Mariahs before they were bought by Sea Fox, and the service man told me it is a really common issue. I guess the solution is to replace the brass drain sleeve with a new plastic one...I may do that this year, but as a short term fix, I siliconed around the sleeve last fall.
    damage , leak , storage , transom , water
    Gas tank leak syc92868 Original Mariah Talk 36 07-16-2013 01:56 AM
    oil leak at lower unit stepchild_7 Mercury MerCruiser 1 11-11-2010 11:58 PM
    drive and leak berk1402 Boating 101 1 05-20-2010 03:10 AM
    Fuel Tank Leak Roger Butterfield Mercury MerCruiser 10 05-27-2009 05:15 PM
    Found my small leak! Captain Steve Original Mariah Talk 3 10-05-2008 02:31 PM
    There are 353 users
