Speedo Question
Old 07-22-2010, 09:38 PM   #1
apickens99 is currently offline
My Model: Z272 Shabah
My Engine: 502 Mag Bravo I
Send apickens99:
Default Speedo Question
I have 1998 Mariah Z272 with the Bravo 1 outdrive. The Faria Speedometer is not reading accuratly. I have read many of the posts regarding no or low readings due to the clogged port, or pitot tube on the outdrive. However, mine seems to have the opposite problem... it is reading way to high. When you are cruising, it will not stop climbing until the needle is buried. Any suggestions? Taking it out and sending it Faria for warranty work may be a winter project.
  • Old 07-23-2010, 07:25 AM   #2
    Default Re: Speedo Question
    Hi apickens99, I've got to admit, hearing about an over-active speedo is a first for me as well, definitely sounds like the pressure system in the gauge has weakened over the years so sending it back to Faria sounds like the right thing to do.
    Good luck,
    Having problems with Tach & Speedo rickt48 Original Mariah Talk 9 06-21-2011 02:52 PM
    Help with the speedo guys embasun Original Mariah Talk 2 01-31-2010 07:46 AM
    Speedo problem embasun Original Mariah Talk 8 01-19-2010 02:00 PM
    Borken Speedo cometb Original Mariah Talk 8 09-29-2009 07:13 PM
    Speedo Repair bpfirrman Mercury MerCruiser 14 04-29-2008 06:04 PM
    There are 334 users
