Speedo problem
Old 01-15-2010, 06:35 AM   #1
embasun's Avatar
embasun is currently offline
My Model: z250
Send embasun:
Default Speedo problem
Can anyone help the Speedo has stopped working is there away to test it when the boat is out of the water thanks
  • Old 01-15-2010, 01:52 PM   #2
    jeffro788's Avatar
    jeffro788 is currently offline
    My Model: 180 Shabah
    My Engine: 4.3L Alpha One
    Send jeffro788:
    Default Re: Speedo problem
    I don't know if it is a good idea or not, but you can gently blow a little air into the pickup on the front of the lower unit. If it is not working your hose may be unplugged on the front of the unit. Mine wasn't working and that was the problem, the hose had been pulled off. There really isn't much to wrong in a speedo gauge I don't believe. I had one on an aluminum boat that i would blow into the pick up tube to test if it was working.
    Thank you jeffro788 for this useful post!
    embasun (01-15-2010)
    Old 01-15-2010, 02:40 PM   #3
    This is an incredibly common problem. The pickup is on the outdrive itself, it will clog from time to time with debris. Before you go trying to blow air in it, try and clean out the hole with a small nail or bent coat hanger first. This has been discussed, with diagrams on the forum many times before. Just do a quick search for "speedo" and you'll find everything you need. If it still doesn't work after cleaning, let us know and we'll try and walk you through the next steps.
    Old 01-15-2010, 11:29 PM   #4
    jgreen's Avatar
    jgreen is currently offline
    Gallery Images: 2
    Send jgreen:
    Hi Guys, I have always used pipe cleaners to clean out the pick up tube, I guess I just don't like to use too stiff a wire. Also, on my Bravo III drive, I unplugged the speedo tube from the drive and found the oring had dried and cracked over the years. Easy fix and only 30 cents!
    Jay
    Thank you jgreen for this useful post!
    embasun (01-16-2010)
    Old 01-16-2010, 12:52 PM   #5
    embasun's Avatar
    My Model: z250
    Send embasun:
    please could you help i have looked for the pipe and can't find it do you know where it is thanks
    Old 01-16-2010, 01:09 PM   #6
    dudders's Avatar
    dudders is currently offline
    My Year: 2006
    My Model: SX18
    My Engine: V6 4.3L
    Gallery Images: 53
    Send dudders:
    At the front bottom of your outdrive, its a tiny hole the size of a match stick, about 5" up from the bottom.
    Tony
    Perth, Western Australia
    Old 01-16-2010, 01:21 PM   #7
    embasun's Avatar
    My Model: z250
    Send embasun:
    Thanks i will have a look tomorrow
    i will let u know if i find it
    Chears
    Old 01-19-2010, 01:17 PM   #8
    Yough_Lake's Avatar
    Yough_Lake is currently offline
    My Model: Z198 Shabah SS
    My Engine: 5.7 LX
    Send Yough_Lake:
    I used to work on outboards alot. I found that the nylon string used for weedwackers is great for clearing the clogged lines for sump pumps - would work on the speedo too. If you have a roll you could potentially fish it from the speedo end back to the lower unit.
    Old 01-19-2010, 02:00 PM   #9
    embasun's Avatar
    My Model: z250
    Send embasun:
    Chears
    Having problems with Tach & Speedo rickt48 Original Mariah Talk 9 06-21-2011 02:52 PM
    Borken Speedo cometb Original Mariah Talk 8 09-29-2009 07:13 PM
    bad problem dmg5606 Mercury MerCruiser 3 06-03-2009 12:20 AM
    Speedo Repair bpfirrman Mercury MerCruiser 14 04-29-2008 06:04 PM
    Name this Problem ShabahZ280 Original Mariah Talk 5 10-09-2007 01:41 PM
    There are 363 users
