Barchetta Handling
Old 07-07-2010, 10:39 AM   #1
cwdog2001 is currently offline
My Model: 1994 Barchetta Z192 3.0L Alpha I
Send cwdog2001:
Default Barchetta Handling
I have a 94 Barchetta 3.0L I/O. With passengers or alone, many times when at speed, the boat will "list" to the port side. This requires a hard turn of the wheel to get the boat "flat" again. Any thoughts would be appreciated.
Also, I tried to use a Sea Ray foil on my cavitation plate. Bad results. Worked great on other boats I've had. I don't understand.
  • Old 07-07-2010, 06:43 PM   #2
    Rdrdon's Avatar
    Rdrdon is currently offline
    My Model: Shabah 200 Limited Edition
    My Engine: 5.7L, Alpha One
    Send Rdrdon:
    Default Re: Barchetta Handling
    Look at the thread about Smart Tabs, they will be your best "cure".
    Old 07-08-2010, 02:03 AM   #3
    Paul F's Avatar
    Paul F is currently offline
    Gallery Images: 4
    Send Paul F:
    That list to port is caused by reaction of your hull to the torque of your prop. My stainless steel prop caused my boat to list more than the stock aluminum. I'm thinking it's because the SS prop had a wider diameter.
    On my boat, smart tabs didn't cure the problem, however, they do allow you to trim the outdrive higher at slower speeds which will level out your ride.
    Old 07-08-2010, 02:15 AM   #4
    SEMIJim's Avatar
    SEMIJim is currently offline
    My Model: 182 Barchetta
    Send SEMIJim:
    Hmmm... Can't say as I've ever noticed that with our '94 182 Barchetta.
    Jim
    Old 07-08-2010, 02:46 AM   #5
    ggrims is currently offline
    My Model: Shabah
    My Engine: 350 magnum
    Gallery Images: 2
    Send ggrims:
    Stainless props bite the water harder as they do not flex like aluminum. They can cause a different handling of the boat. The advantage of stainless is they wont flex, or straighten out under load making them better for performance, the bad part is they are so rigid that when you hit something, something in your drive can break before they do.. Aluminum blades are soft so they actually decrease in the pitch as you put them under load.
    Old 07-08-2010, 03:16 AM   #6
    Paul F's Avatar
    Gallery Images: 4
    Send Paul F:
    I'm sure the lack of flex in addition to the diameter are contributing factors.
    I've struck wing dams and logs, damaged both aluminum and stainless steel, but the rubber bushings have always saved my gearcase so far.
    Old 07-08-2010, 03:17 AM   #7
    Paul F's Avatar
    Gallery Images: 4
    Send Paul F:
    Jim
    What prop are you running, Jim?
    Old 07-08-2010, 01:22 PM   #8
    SEMIJim's Avatar
    Send SEMIJim:
    I've had both a High-5 stainless and a plain old MerCruiser 3-blade aluminum, both 14-1/4", 23p. Currently it's the 3-blade Al, ever since the H-5 was damaged by hitting something on the bottom of the lake.
    Jim
    Old 07-08-2010, 07:33 PM   #9
    Paul F's Avatar
    Gallery Images: 4
    Send Paul F:
    Jim
    Interesting... Perhaps the High 5 has less pitch, thus less torque?
    Old 07-23-2010, 11:21 PM   #10
    coolfish is currently offline
    My Model: barchetta 182
    My Engine: 4.3 merc alpha 1
    Send coolfish:
    I also have this problem with my 1994 Barchetta 4.3. I have tried a "whale tail" on my outdrive which helped keep the bow down a bit. Going to try smart tabs next as I still don't think I could pull up an adult on skis. The bow is still too high and won't come down without a peson in the bow. RPMs at WOT is about 5000 with the plate on the drive (was 4800 before the plate). 14 " prop with 19 pitch aluminum. When I have passengers, the boat tips hard to the port side until I start to plane out and bring the trim up. Scary sometimes. Just as baffled as you.
    Shawn
    horse power handling 96blackmariah Original Mariah Talk 7 04-06-2009 08:41 PM
    Looking for a Bimini Top for a 94 Barchetta 182 djmccormick Original Mariah Talk 2 02-03-2009 12:58 PM
    Rough water handling guidelines Tilted Boating 101 6 10-14-2008 10:30 PM
    Hello! 95 z 272 Barchetta owner here luv2boat Introductions 3 08-13-2008 09:21 PM
    94 182 barchetta brett weber Introductions 6 02-20-2008 05:38 PM
    There are 225 users
