Front Window not closing
Old 05-18-2010, 01:56 PM   #1
jeffro788's Avatar
jeffro788 is currently offline
My Model: 180 Shabah
My Engine: 4.3L Alpha One
Send jeffro788:
Default Front Window not closing
Does anyone know if there is a way to adjust the front window so that it closes easier? Right now when I try to close it the frame on the window hits the frame on the windshield at the top. You have gently push up on the top of the windshield glass to get it to close. I really hate forcing the window to shut.
  • Old 05-18-2010, 02:38 PM   #2
    1stDave's Avatar
    1stDave is currently offline
    My Model: Z275 Shabah
    Gallery Images: 3
    Send 1stDave:
    Default Re: Front Window not closing
    Sounds as if you need a slight adjustment.
    Try loosening the support bars at the windscreen then have someone push up slightly, now retighten the screws.
    That should do it.
    ps. don't overtighten or you could strip the screws.
    Old 05-18-2010, 04:42 PM   #3
    jeffro788's Avatar
    Send jeffro788:
    I wondered if that would help, it just looks like there is a lot of geometry involved. I may be blowing it out of proportion though. But I am afraid of damaging that glass from it being in a bind so I need to try something.
    Old 05-18-2010, 07:16 PM   #4
    Phlorida is currently offline
    My Model: 250 Sundancer
    My Engine: 5.7L Bravo II
    Send Phlorida:
    Dave is right, just loosen the screws and put it the way you want it and then tighten them up. This is fairly common and typically required every couple of years.
    Old 05-18-2010, 08:00 PM   #5
    jeffro788's Avatar
    Send jeffro788:
    Thanks guys will give that a shot. I just hope I have enough slack to do that. Do I really have to worry much about damaging that glass?
    Old 05-18-2010, 08:24 PM   #6
    nah, Phlorida and 1stDave are right, you should be okay as long as you are reasonably careful. I would stick a small spacer in the top & bottom of the framework so that the gaps are even & then tighten the support bars back up. If that adjustment doesn't quite work (but it should), you can also remove the rubber/foam trim strip & gain access to the windshield mounting screws. Loosen them a bit and there should be some slight movement in the window frame.
    Old 05-18-2010, 08:26 PM   #7
    Send Phlorida:
    Jeffro -
    All of the glass on my boat is encased in metal and the supports are screwed into the metal frame. The glass is all safety glass so no, you would have to work hard to break it. When i loosen the support screws on my boat there is a lot of play to do the proper adjustments.
    Again, the proces that I use is to loosen the supprt screws, align the door, hold the glass so that there is a bit of a gap between the windshield frame and the door and then tighten all of the screws back. AS the previous poster (Dave?) indicated, you want to snug up the screws but now so tight that you strip them or snap them off.
    You will be fine.
    Thank you Phlorida for this useful post!
    Dredd (05-19-2010)
    Old 05-19-2010, 12:49 PM   #8
    jeffro788's Avatar
    Send jeffro788:
    thanks guys, will give it a shot.
    Walk through window Kitto Original Mariah Talk 4 06-09-2009 01:33 AM
    Wanted: Window Mariah Z 250 needed Edward Mariah Parts For Sale & Wanted 0 06-08-2009 09:24 PM
    Side Vent Window Handle Colin Logie Original Mariah Talk 9 05-13-2009 04:42 PM
    Temp Window JohnZ202 Original Mariah Talk 1 05-01-2008 08:02 AM
    There are 367 users
