hull repair
Old 04-27-2010, 01:04 AM   #1
candanewell is currently offline
My Model: 202
Send candanewell:
Default hull repair
I recently repaired a small scratch on my hull. I used a gel coat repair kit followed by a light sanding with wet600 glass paper and then polishing with electric buffer and maglens pure wax.
The problem I have is that I cannot polish out the scratches from the 600 wet sanding I conducted. Reading on line instructions it looks like I did the correct things and the surface I have is smooth, but dull and not shiny as the rest of the hull
Can any help and advise me how to get the shine back or what else I could do?
  • Old 04-27-2010, 01:18 AM   #2
    jgreen's Avatar
    jgreen is currently offline
    Gallery Images: 2
    Send jgreen:
    Default Re: hull repair
    Did you go straight to wax after the sanding? If so I think you skipped a step. You need to hit it with compound on your buffer before you polish. I would strip the wax with wax & grease remover and then give it a good rubbing with 3M liquid rubbing compound.
    Let us know how it turns out.
    Jay
    Old 04-27-2010, 07:30 AM   #3
    Hi candanewell, I agree with jgreen, and I would like to add to what he said, so follow the rubbing compound with a polishing compound and then follow with the wax when the shine is restored.
    Wax does not smooth away scratches, it's more of a sealer, it's the rubbing and polishing compounds that remove those fine scratches and give you that shiny surface.
    Take a look at this project member ShabahZ250 documented when he had to do some hull repairs and how he got the shine back - click here.
    Old 04-27-2010, 02:33 PM   #4
    jgreen's Avatar
    Gallery Images: 2
    Send jgreen:
    Right on WW, I guess I skipped a step myself. Also, start with a pretty aggressive pad on the buffer and work down with each different compound.
    Jay
    Old 04-27-2010, 03:49 PM   #5
    Dredd's Avatar
    Dredd is currently offline
    My Model: MX-19 - Sold
    Send Dredd:
    Definitely let us know how it turns out! I've got a couple scratches myself that I've been reluctant to fix (using the Marine Tex I bought a while back) because I'm afraid I won't be able to get the shine back.
    Old 05-09-2010, 08:32 PM   #6
    My Model: 202
    Send candanewell:
    just wanted to say thank you for the below advice and while I could not get mirror perfection I was able to get the shine back, the rubbing compound appeared to do the trick, together with some color restorer and elbow grease!
    Thru Hull Transducer 300sflyer Original Mariah Talk 4 09-28-2010 02:20 PM
    Need help with hull ID mjhinno Introductions 9 10-05-2009 10:31 PM
    Hull Cleaning andyc General Maintenance 5 10-01-2009 09:38 PM
    Thru-hull conversion. doofusmarine Original Mariah Talk 1 08-01-2009 12:10 AM
    hull repair bpfirrman General Maintenance 5 04-30-2008 02:31 AM
    There are 331 users
