Thru Hull Transducer
Old 01-31-2008, 02:15 PM   #1
Send 300sflyer:
Default Thru Hull Transducer
Does anyone know where in the hull, Mariah put the factory installed transducer for the Lowrance depth sounder? [3500] I had a bit of trouble with mine last fall, and wanted to check to make sure it was still secure.
  • Old 01-31-2008, 03:04 PM   #2
    Mine is located in the bilge area under the rear of the engine. My Lowrance 3500 was giving me some trouble too, found out the epoxy on the transducer and the mount had gone bad, leaving the transducer just kind of hovering in the bilge area. I've got a new transducer waiting to be installed once the weather warms up a bit. It's a lowrance PD-N.
    We discussed this a few weeks ago in the off topic forum.
    Fish Finders
    Hope this helps!
    Old 01-31-2008, 04:17 PM   #3
    Z 202's Avatar
    Z 202 is currently offline
    My Model: Mariah Shabah 202
    My Engine: 5.7L Alpha 1
    Send Z 202:
    I have the Uniden model sounder and the transducer is also in the bilge area, but towards the front of the engine.
    My Mariah
    Old 02-01-2008, 12:06 PM   #4
    Send 300sflyer:
    Thanks for the info guys!
    Old 09-28-2010, 02:20 PM   #5
    845paulg is currently offline
    My Model: Shabah Z 272
    My Engine: 7.4 L MPI Bravo III
    Gallery Images: 12
    Send 845paulg:
    Default Re: Thru Hull Transducer
    I have a 1996 272 and it is delaminated too from the rear of the beilge area, under the engine. I'm replacing with transom mount combo unit that has other functions as well.
    Hull Identification Numbers (HIN's) ShabahZ280 Boating 101 1 04-19-2013 05:52 PM
    hull repair bpfirrman General Maintenance 5 04-30-2008 02:31 AM
    MaryKates on/off Hull Cleaner MariahShabah3.0 General Maintenance 6 09-01-2007 01:17 AM
    There are 272 users
