power steering pump bracket
Old 02-28-2010, 07:43 PM   #1
jetscat7 is currently offline
Send jetscat7:
Default power steering pump bracket
The bracket that the pump is mounted to is rusted out. Where can I get a new mount bracket? This is the only part of this 95 mariah that is rusted out. Is this common? Any help would be appreciated.
  • Old 03-01-2010, 01:14 AM   #2
    IowaWing is currently offline
    My Model: 190 Talari
    My Engine: 4.3 L Alpha 1 Gen2
    Send IowaWing:
    Default Re: power steering pump bracket
    What year, brand and size engine do you have?
    IowaWing
    Steve
    Thank you IowaWing for this useful post!
    jetscat7 (03-01-2010)
    Old 03-01-2010, 05:10 AM   #3
    Send jetscat7:
    1995 Talari 190z with a 4.3lx merc engine.
    Old 03-01-2010, 02:15 PM   #4
    jgreen's Avatar
    jgreen is currently offline
    Gallery Images: 2
    Send jgreen:
    Your're pretty lucky, that bracket shows "no longer available" on the mercruiser parts site but I did find one on Ebay.
    Check out Mercruiser V6 & V8 Power Steering Pump Bracket 15082T : eBay Motors (item 370339678960 end time Mar-24-10 15:49:47 PDT)
    Hope it works for you.
    Jay
    Thank you jgreen for this useful post!
    Old 03-01-2010, 04:12 PM   #5
    Send jetscat7:
    Wow thanks for all the help but now that I see the picture I believe I have made a mistake in the description of the piece that I need. It seems to be connected to the hydraulics of the outboard. If you are looking at the engine compartment from inside the boat it is on the right far back. There is a metal bracket that holds some sort of hydraulic fluid assembly. The base of this bracket is all rusted and I am afraid it will break and bounce around at speed. I will try and take a picture of it and post it for confirmation. I am sorry I don't know the name of the part. I am new to this stuff.
    Old 03-01-2010, 05:17 PM   #6
    Send IowaWing:
    Sounds like the lift pump reserve tank bracket?
    IowaWing
    Steve
    Old 03-01-2010, 05:26 PM   #7
    Send jetscat7:
    So you mean the fluid for setting the trim? What does that bracket look like. I will know it when I see it. If it is that bracket are they out there and where do I find it?
    Old 03-01-2010, 05:43 PM   #8
    jgreen's Avatar
    Gallery Images: 2
    Send jgreen:
    Is this it?
    http://www.mercruiserparts.com/Show_...MP+AND+BRACKET
    Jay
    Old 03-01-2010, 05:49 PM   #9
    Send jetscat7:
    I think that is it. So I will go take a closer look at mine and compare the hole config. Is this the place to order it? Thank you all so much. I would have never found this.
    Old 03-01-2010, 06:10 PM   #10
    jgreen's Avatar
    Gallery Images: 2
    Send jgreen:
    Hi, the link I sent is just one on line parts supplier, there are a bunch of them. There are some on Ebay too. Good luck.
    Jay
    « 95barchetta | seats »
    power steering question depman160 Boating 101 2 11-12-2009 08:42 PM
    power trim pump fbinker Original Mariah Talk 3 04-30-2009 04:50 AM
    2350 Z power steering cleah Mercury MerCruiser 2 09-09-2008 02:17 AM
    changing power steering pump 01DiabloMissouri Original Mariah Talk 2 07-09-2008 01:51 PM
    Power Steering boarder1010 Boating 101 2 07-08-2008 03:38 AM
    There are 273 users
