Tight steering
Old 02-26-2010, 06:36 PM   #1
Royster is currently offline
My Model: 1997 Z244 Jubilee 454 Merc Cruiser
Send Royster:
Default Tight steering
We have a '97 Jubilee Z244 and the steering is very tight and hard to steer. The power steering pump is full and appears to be working. Can the tension on the steering be adjusted and if it needs to be replaced do you have any suggestions?
  • Old 02-26-2010, 10:09 PM   #2
    Default Re: Tight steering
    Hi Royster, as far as I know, there isn't any "tension" adjustments for stiff steering.
    Four things are normmaly associated to this condition:
    1) Binding in the steering wheel assembly. (Parts are worn and/or need lubing)
    2) The steering cable. (inner cable is worn/cable lube is dried up/contaminated or both)
    3) The power steering system. ( valve or internal pump parts mat be leaking causing drop in pressure)
    4) Gimbal pivots. (worn/corroded/out of lube)
    For starters, I would begin troubleshooting by isolating the cable/steering box/powersteering from the gimbal as I beleive this is the easiest to do:
    1) Start by removing the big pivot bolt holding the cable/powersteering valve to the gimbal steering arm.
    2) Now try turning the steering wheel, if it's still tight, your problem is either in the steering box or the cable (I would suspect the cable first), but if it's smooth then it's in the outdrive or powersteering system.
    Give it a try and keep us updated so we can assist you further if you need it.
    Good luck,
    Thank you WetWilly for this useful post!
    Royster (02-26-2010)
    Old 02-26-2010, 11:04 PM   #3
    Send Royster:
    I really appreciate your prompt reply and I'll yet you know what the solution is.
    Old 05-30-2013, 01:35 PM   #4
    Niv
    Niv is currently offline
    My Model: Brachetta
    My Engine: 4 cylinder
    Send Niv:
    i had the same problem , mechanic said keep driving and it will eventually losen up. Can that be true? we have not taken boat out in 3 years
    Old 05-30-2013, 03:42 PM   #5
    Niv ,
    Find another mechanic.
    The system doesn't just naturally fix itself.
    Start at WetWillys post above
    Old 05-30-2013, 04:40 PM   #6
    And...do a site search for 'steering' and you will find numerous threads discussing this same topic.
    Steering on '96 Shabah jchemotti General Maintenance 5 05-15-2010 08:44 PM
    Hard Steering Kirkyer Introductions 0 07-19-2009 12:53 PM
    hard steering duketter Original Mariah Talk 2 06-07-2009 02:47 PM
    Hard steering Jimh23 Original Mariah Talk 4 06-05-2009 10:52 AM
    Steering Lube jakejorgenson General Maintenance 1 01-27-2009 03:25 PM
    There are 228 users
