Bilge pump rewire question
Old 05-30-2013, 03:31 AM   #1
rhinoz is currently offline
Send rhinoz:
Default Bilge pump rewire question
I have a 96 Shabah 180 and I was wanting to know how to wire a straight 2 wire bilge pump...reason I ask is that there was no bilge pump in the boat and I have 5 wires out of a harness capped off. I'm guessing the pump was 3 wires and 2 of the others were the auto pump switch.
So this is my solution to at least having a bilge pump without playing "eeni, meeni, miini mo" etc with the 5 wires.
Am I right in saying I run from battery (+) to fuse holder, fuse holder to one side of switch, then other side of switch to positive (black wire) on pump...then brown wire from pump straight to battery (-) ?
Would a 10amp fuse suffice or would a 20 be too much, its a 650gph pump..
  • Old 05-30-2013, 12:35 PM   #2
    Default Re: Bilge pump rewire question
    Why not use your original wiring.
    Brown - Positive
    Brown/White - Auto Switch Positive
    Black - Ground
    The wiring for your boat is available to contributing members.
    You can check out all the benefits here.
    A 5 amp fuse should work. That size pump will draw around 2.5 - 3 amps.
    Old 05-30-2013, 12:57 PM   #3
    Send rhinoz:
    Brown - Positive
    Black - Ground
    So as I have a 2 wire pump, just use the brown and black...Got it...
    Contributing member now
    Old 05-30-2013, 01:05 PM   #4
    Yep!
    Lots of great info as you will soon find out in "Members Benefits".
    Old 05-30-2013, 01:17 PM   #5
    Send rhinoz:
    Yep!
    I see that..printed wiring diagram for the boat. My goal is to get everything else wired in the next couple of days so I can take it out on the water for the first time.
    Things to do:
    Connect bilge pump: check
    Change nav bulbs
    Find a midget who can crawl under the dash and check the fuses for blower and bilge!
    Old 05-30-2013, 01:23 PM   #6
    I here ya!!
    I can get under the dash on my Diablo , but momma has to pry me out with a paddle
    Old 05-30-2013, 01:30 PM   #7
    Send rhinoz:
    I here ya!!
    No doubt, I was wedged last night as I was working on changing a very tired looking trim inline fuse, changed it from glass style to blade style..I thought the missus was going to have have to get me out with WD-40 and a tire iron lol
    Just wondering if anyone has a diagram of the fuse panel for a Shabah, that would help out big time!
    Bilge pump alliedasset Boating 101 2 05-30-2012 02:36 AM
    Shabah 18 factory bilge pump location question eroc37 Original Mariah Talk 3 05-05-2012 10:25 PM
    Bilge pump question nglauer Original Mariah Talk 7 07-27-2010 01:44 AM
    Bilge pump andyc Sea Fox - Mariah Talk 7 07-14-2009 04:01 PM
    bilge pump John Miller Original Mariah Talk 7 05-18-2009 07:25 PM
    Total Members: 18,990
    Total Threads: 13,324
    There are 184 users
