Water in boat?
Old 07-09-2009, 04:23 PM   #1
duketter is currently offline
Send duketter:
Default Water in boat?
1996 Mariah Jubilee with captains exhaust - Is it possible for water to come into the back of the boat (fill bottom back of boat by engine) through the exhaust pipes sticking out the back? This boat has the captain's exhaust system. It seems like there is always a little water in the back after boating. We run the bilge pump and it takes the water right out but curious where this water could be coming from?
  • Old 07-09-2009, 05:15 PM   #2
    Z 202's Avatar
    Z 202 is currently offline
    My Model: Mariah Shabah 202
    My Engine: 5.7L Alpha 1
    Send Z 202:
    Default Re: Water in boat?
    It's probably not coming from the exahust.
    How much is "a little"? Water in the bilge could be a couple of things; cool water on exterior of the hull causes condensation from the humid air in the boat, it's also possible that one of your coolers drains into the bilge.
    If you are getting substantial water in the bilge, the most likely culprit would a crack in the drive bellows, or the a leak at the smaller bellows on the shift cable.
    My Mariah
    Old 07-09-2009, 06:07 PM   #3
    Send duketter:
    I guess I shouldn't say a little. I would say about a gallon of water or two. So maybe not a little. Is there anyway to check those bellows? What exactly are they, the rubber boots by the lower unit? We really haven't filled any coolers in the boat so may have to check the bellow option you mentioned.
    Old 07-09-2009, 07:01 PM   #4
    Z 202's Avatar
    Send Z 202:
    Yes, the bellows is the rubber boot that flexes as you trim the drive It is located between the top of the outdrive unit and the transom assembly. It you trailer trim your drive, you should be able to look up and see them. Inspect for any cracks or broken/rusted clamps. The shift cable has a smaller bellows on it as well.
    My Mariah
    Old 06-14-2010, 07:52 AM   #5
    RKgrubbs is currently offline
    My Model: ?
    My Engine: ?
    Send RKgrubbs:
    you might want to check the hull for "blisters". Water could seep in through them and drain to engine compartment.
    Old 06-14-2010, 02:08 PM   #6
    jgreen's Avatar
    jgreen is currently offline
    Gallery Images: 2
    Send jgreen:
    Indeed you should check the exhaust too. If you look at the manifolds, you see rubber sleeves connecting the "Y" that directs the exhaust to the prop or the transom to the transom pipes. These should be clamped with double stainless steel hose clamps. Make sure they are tight and leak free. A loose hose clamp here can fill your bilge up pretty fast. (ask me how I know!)
    Get yourself a flushing attachment too. Then you can run the engine out of the water to check hoses. If there are no leaks then it might be a bellows on the outdrive.
    Jay
    Old 06-14-2010, 02:31 PM   #7
    1stDave's Avatar
    1stDave is currently offline
    My Model: Z275 Shabah
    Gallery Images: 3
    Send 1stDave:
    If you have a lot of swimmers, skiers, wakeboarders etc. the water that drips from them after being in the water can be that much.
    Old 06-14-2010, 03:14 PM   #8
    My Model: ?
    My Engine: ?
    Send RKgrubbs:
    1stDave
    Thanks for your reply.
    That is a good thought.
    In my case it was just sitting in the water and sucking up the lake.
    Old 06-14-2010, 03:27 PM   #9
    My Model: ?
    My Engine: ?
    Send RKgrubbs:
    JGREEN
    Pease tell how you know....
    Old 06-14-2010, 03:32 PM   #10
    Boatcrazy is currently offline
    My Model: Z302
    My Engine: 502 MPI / Bravo III
    Gallery Images: 548
    Send Boatcrazy:
    Does your speedo work?
    I have a friend that I helped look for the source of a slow leak in the bilge and I found the speedo tubing that comes from the transom plate up to the speedo had a small crack in it and would only leak when underway. Just a thought.
    Finally going to get my boat on the water!!! cholschlag Original Mariah Talk 6 05-30-2008 02:14 AM
    how much water do you take on? bpfirrman General Maintenance 7 04-29-2008 09:35 PM
    First problem on water! (boat is ok and I'am) 180diablo Chit Chat/Off-Topic 0 08-20-2007 01:18 PM
    There are 299 users
