how much water do you take on?
General Maintenance
Old 04-29-2008, 01:30 AM   #1
Send bpfirrman:
Default how much water do you take on?
I am new to boating, just a disclaimer. I have taken out my boat three times. First time, took the plug out and ZERO water came out. Second time about 1/2 an ounce came out. Third time probably 1/4 cup came out. Everyone tells me that it will take on a little water, just wonderning why and how much is acceptable. I have yet to use my bilge and it has never come on automatically. I don't think the boat has ever taken on any water, engine area looks absolutely brand new.
  • Old 04-29-2008, 02:17 AM   #2
    When the water gets up around your ankles....you've taken on too much.
    Seriously though... most boats have a bit of water in the bilge particularly if they're left moored in the water. Rain, boat wakes, stern wash etc all trickle in at various points and unless the water gets up past the bilge pump & it doesnt start working it shouldn't be an issue.
    Old 04-29-2008, 02:21 AM   #3
    Z 202's Avatar
    Z 202 is currently offline
    My Model: Mariah Shabah 202
    My Engine: 5.7L Alpha 1
    Send Z 202:
    Well that's a good thing right? A boat that doesn't leak...
    Any water that mine has taken on has come pretty much exclusively though my top (rain water) or water off the passengers as they board . (Which is OK though as women in wet bathing suits are always welcome on my boat.)
    On my Shabah when the bilge pump begins to suck air, there are still a couple of cups of water in the back. That's about the most I've ever had come out the drain plug.
    I've done lauches and come back dry.
    Even if the top is tight and doesn't leak, storing the boat in the water for periods will cause moisture to condense on the inside of the hull and eventually fill the bilge.
    My Mariah
    Old 04-29-2008, 05:56 PM   #4
    180diablo's Avatar
    My Model: 1993 Diablo 180
    Gallery Images: 30
    Send 180diablo:
    My bilge stayed pretty wet for most of the summer. Not enough for cause concern, but enough that it was visible and the bilge pump could not pickup anymore water.
    I know I have posted this same topic before on here, but according to my uncle, having a bit of water in the bilge is fine. If raw fuel happens to leak/dump into the bilge, then the water is there to sort of filter out the raw fuel and make it less lethal to explosions.
    Another good tool to keep on board (yep I have one).
    http://www.carlislepaddles.com/downloads/bilge_pump.jpg
    http://www.ajaytrading.co.uk/media/HandBilge.JPG
    These pumps will get just about all the water out from back there. Just make sure the hose is long enough that it can pump the water overboard. I managed to swamp the bow of my boat last summer and immediately my girlfriend grabbed the pump and began pumping while I was keeping the bow up and running the bilge. We were ok after about 5minutes or so of pumping.
    I'am still curious to see how much water we actually took on that day. She told me "you don't want to know".
    ~ Ryan
    Owner of the 3.0L Powerhouse!
    Old 04-29-2008, 06:40 PM   #5
    indykoch's Avatar
    indykoch is currently offline
    Send indykoch:
    I could go sooooooo many places with this... but it's a clean board and I'll let Mikeyt have the floor...
    Ryan
    Previously - '99 Z212 Shabah
    350 Mag MPI
    Old 04-29-2008, 08:40 PM   #6
    I am not gonna say anything on this one.....
    Old 04-29-2008, 09:35 PM   #7
    180diablo's Avatar
    Gallery Images: 30
    Send 180diablo:
    bugger
    ~ Ryan
    Old 04-29-2008, 09:35 PM   #8
    180diablo's Avatar
    Gallery Images: 30
    Send 180diablo:
    bugger
    ~ Ryan
    High water @ my cottage 180diablo Chit Chat/Off-Topic 8 04-15-2008 12:27 PM
    Should a z272 have a water tank? bblauvelt Original Mariah Talk 3 03-11-2008 09:38 PM
    Just for Fun, Best Water Sports Pics... WetWilly Watersports 1 10-19-2007 07:12 PM
    Water in bilge .. good or bad? 180diablo Original Mariah Talk 6 10-07-2007 05:44 AM
    There are 303 users
