Control arm not shifting out of forward
Old 06-25-2009, 08:43 PM   #1
Lunaticutah is currently offline
My Model: 2000 Z250 Limited 7.4 L Bravo I
Gallery Images: 3
Send Lunaticutah:
Default Control arm not shifting out of forward
I just bought a 2000 Z250 and put it in the water for the first time and it wont go into neutral or reverse. I pulled the control arm all the way back to the reverse postion and it wont even hit neutral. The cables are attached and moving on the engine mount assembly but I can't see where the cable connects to the outdrive.
Do I have to pull the whole out drive off to change out cable? Any advice would be great!
  • Old 06-26-2009, 03:39 AM   #2
    Default Re: Control arm not shifting out of forward
    Hello Lunaticutah,
    If it's the secondary shift cable to the outdrive, then the answer is yes, the outdrive has to come off.
    Section 4 of the Bravo Sterndrive manual explains the procedure. It starts on page 4A-20.
    Unless you're familiar with or have done this repair before, I suggest taking it to a qualified Merc service center.
    Old 06-26-2009, 01:16 PM   #3
    karmann is currently offline
    Send karmann:
    Hello
    I just had the same problem. You have to pull the out drive back, to switch out the cable. Mine was rubbing the U-joints on the drive shaft, and wore out the outter hsg.
    thanks
    Old 06-26-2009, 04:14 PM   #4
    Gallery Images: 3
    Send Lunaticutah:
    I'll give a wack at it.
    Throttle Control Shifter Question? Douglas Alderman Original Mariah Talk 21 06-25-2009 07:44 PM
    Clarion Remote Control @ helm il_Mio Sea Fox - Mariah Talk 8 08-03-2008 12:45 PM
    Engine/trim control replacement Mark from Long Lake Mercury MerCruiser 2 07-29-2008 02:18 AM
    Remote control tnmc13 Original Mariah Talk 10 03-13-2008 02:40 AM
    question about shifting 180diablo Mercury MerCruiser 0 07-24-2007 09:58 PM
    There are 248 users
