raising my deck lid
Old 06-09-2009, 07:32 PM   #1
paulbroeder is currently offline
My Model: 1994 Z210 Talari 4.3LX Alpha I
Send paulbroeder:
Default raising my deck lid
I have a Z210 Talari and am experiencing trouble with the two linear actuators that raise and lower the lid. Where do I get new ones? Also, I noticed the switch has been replaced. Anyone out there got any advice???
  • Old 06-10-2009, 12:23 AM   #2
    Default Re: raising my deck lid
    Hi Paul,
    What kind of trouble are you having with the lifts? Are the making a lot of noise, not working at all or go up and down at different speeds?
    If you want or need to change them out, we have a listing for the lift and the switch sources. Look in the "Original Mariah Talk" forum, the third thread is the "Mariah Parts List" sub-forum. Here you will find the lifts in the"Engine Hatch" section and the switch in the "Switches" section.
    Good luck,
    Old 06-13-2009, 10:59 PM   #3
    Mariahmanic's Avatar
    Mariahmanic is currently offline
    My Model: 1994 Z212 Shabah 350 Mag Alpha 1
    Send Mariahmanic:
    Hey Paul,
    Have been able to fix your lift problem?
    Do you have power to them, or do they just run at different speed?
    I have a 1994 Shabah Z212 with twin lift actuators made by Acculift. I had a problem with them not running in sync. (one slower than other). I spoke with someone from the factory and was told to give the gearbox a good shot of grease and clean and lube the chrome extension tubes with WD40. That was last year. All is still fine.
    I also found I needed to remount one of the actuator lower mount brackets because at full stroke, they caused the swim pad to be uneven, and when retracted, caused one side to pull too far into the back bench cushions.
    Hope this helps,
    Paul H.
    Old 06-16-2009, 05:58 PM   #4
    sanitycheck is currently offline
    Send sanitycheck:
    Hi Had a problem that they worked than died after two mor three cycles. The battery was DEAD - would hold only a surface charge from the plugged-in onboard charger.. Cut wires, chased switches, etc. Finally noticed that radio died after two minutes when only the #1 battery was being used. Try the other battery- switch wires or check the battery.
    94 Davanti Swim Deck brettk Original Mariah Talk 0 05-14-2009 04:52 PM
    help on sun deck s.a.charlie Original Mariah Talk 0 10-12-2008 07:29 PM
    214 Deck Boat Martony1 Introductions 1 07-10-2008 11:46 PM
    Deck boating rassski Introductions 4 06-02-2008 04:29 AM
    Sun Deck / Engine Cover Acadianbasic Original Mariah Talk 6 06-01-2008 01:14 PM
    There are 244 users
