Ever tried taking the top out of it's holder??
Old 09-04-2007, 01:20 PM   #21
180diablo's Avatar
My Model: 1993 Diablo 180
Gallery Images: 30
Send 180diablo:
Didnt snap any pics .. but there is NO way my top is going in under the engine compartment hatc area. Must have been something they added in the later years.
Pretty much the floor line continues into the engine area and there is no areas to stuff the legs of the top below the flooring. So for now, we just leave it draped over the engine cover OR on the port side along the seats.
~ Ryan
Owner of the 3.0L Powerhouse!
  • Old 10-06-2008, 07:36 PM   #22
    Tilted is currently offline
    Status: In Limbo
    My Model: 1994 Talari 180 4.3L Alpha One, former garage queen!
    Send Tilted:
    I just took the cover out this weekend, and found that the easiest way to put it back in is to put the right leg in first while the assembly is rotated clockwise 30 degrees. Keep lowering it until the upper right corner enters the right hole, then move the top assembly further down and to the right so that the corner is well inside the hole . You've just created enough room to move the bottom left tip into the left hole. Maneuver into place, and you're all set.
    Old 10-06-2008, 08:59 PM   #23
    Hi Tilted,
    Thanks for the tip! I'll have to try that and see if it works out for our Talari.
    BTW, what model and year Mariah do you have?
    Thank you,
    Old 10-07-2008, 12:25 AM   #24
    Status: In Limbo
    Send Tilted:
    A 94 Talari 180
    Old 03-17-2009, 02:21 AM   #25
    kylakerat's Avatar
    kylakerat is currently offline
    My Model: Z220 Talari
    My Engine: 7.4 Bravo III
    Send kylakerat:
    Default Re: Ever tried taking the top out of it's holder??
    New here, and sorry for bringing up an old thread, but Tilted is spot on on getting the top in and out. When I first got my Z220, I fought the top going both ways. Now I can raise the sunpad, get it in/out, and have the sunpad back down in less than a minute easily.
    I added a second battery to my boat (deep cycle to run the tunes while anchored down) so I have to start the left side first because of the big deep cycle on the port side. The main key to getting it in without banging the boat, cussing, or just throwing the thing in the lake is to drop one end in the hole, then pushing to the side to gain the extra room to swing the other side around. You'll actually push part of the curve frame into the hole, but when it's completely in, it will center itself up.
    Hope this helps and maybe some of you will start using the top now that you know how to get it in and out....easily.
    Old 03-17-2009, 04:23 AM   #26
    Irace82's Avatar
    Irace82 is currently offline
    My Model: 1993 Shabah 198 4.3LX Alpha I
    Send Irace82:
    Hmm i took a look at mine and it does have the two rectangular holes in the back under the sunpad but its not even possible because of the gas struts holding the sun pad up. Does everyone else only have one or do they have two? Didnt know if the previous owner added an extra one.
    CD Pocket Holder Douglas Alderman Original Mariah Talk 3 04-18-2008 02:07 PM
    There are 313 users
