Engine cover gas struts modification
Projects
Old 07-15-2008, 12:00 AM   #1
AndyFL
Posts: n/a
Status: Guest
Gallery Images:
Default Engine cover gas struts modification
I've seen a thread awhile back with instructions of how to modify the engine cover's gas struts and brackets (or something to that effect), to make it raise higher for additional clearance...can anyone point the thread to me? I searched the whole site but could not find it.
Thanks/Andy
Mariah SX20
  • Old 07-18-2008, 10:54 PM   #2
    AndyFL
    Posts: n/a
    Status: Guest
    Gallery Images:
    So, noone knows where the thread went...? I am sure I saw it somewhere on this site a couple of months ago.
    I remember the original poster explained that, by flipping (or inverting) the gas strut brackets, the engine cover/tanning pad will raise higher, making the task of working in the engine compartment a lot easier and spacious.
    Anyone knows the steps exactly to accomplish this project?
    Thanks!
    Old 07-20-2008, 08:48 AM   #3
    Hi AndyFL,
    Sorry, but I've tried to find any threads/posts referring to the flipping the brackets for the gas struts, but I'm not having much luck either...
    From what I know of the typical gas strut mounting brackets, you can't flip the upper brackets and if your able to flip the lower one, it would probibly give you only an inch at the most as they are normally triangular in shape with a small peg to mount the strut on.
    Your options would be to relocate your existing brackets to allow the hatch to open more or to install a longer strut. Just be careful that you make sure you have enough distance between the brackets when the hatch is closed for the length of the strut your using or you'll end up jamming the brackets into the strut and no telling what damage that will create.
    Is it possible you saw a post about the brackets for the electric/hydraulic lifts or moving the brackets for more clearance?
    Old 07-20-2008, 07:44 PM   #4
    AndyFL
    Posts: n/a
    Status: Guest
    Gallery Images:
    Thank you for your reply WetWilly.
    After a second and closer search of the site, I was able to find the thread.
    Here is the link:
    http://www.mariahownersclub.com/foru...t=engine+cover
    It basically says to change the placement of the lifting arms, or turn the holding brackets around, (or upside down), like you also suggested.
    I'll try these two options first and see how much clearance I actually gain, otherwise, I will try replacing the struts for longer ones, but taking into consideration the heads-up precautions you point out.
    Thanks again,
    Old 07-21-2008, 06:23 AM   #5
    Hi AndyFL,
    Glad you found the thread! Wow no wonder I couldn't find it...over 9 months old and "lifting arms", never would have thought to look for that one!
    Hey, maybe we can get dudders to post some pictures of his "lifting arms" and bracket location so we can see how he did it, how about it Tony?
    Old 09-22-2010, 12:22 PM   #6
    Brianc=fun is currently offline
    My Model: Shabah Z222
    My Engine: Volvo Penta 7.4Duoprop
    Send Brianc=fun:
    Default Re: Engine cover gas struts modification
    Hello Andy
    Did you manage to get the gas struts installed. I'm facing the same issue and wanted to see the installation photos.
    Cheers
    New upholstery for sun deck/engine cover bdbyrnes Projects 28 01-23-2010 04:25 PM
    Sun Deck / Engine Cover Acadianbasic Original Mariah Talk 6 06-01-2008 01:14 PM
    check out this engine cover 180diablo Chit Chat/Off-Topic 17 04-04-2008 08:43 PM
    Problem w/ power engine cover joe2106 Original Mariah Talk 6 12-28-2007 04:12 PM
    Power ram for engine cover 97 Z222 Original Mariah Talk 2 11-12-2007 09:56 PM
    There are 401 users
