trim moter and water pump
Old 01-14-2009, 03:30 AM   #1
Sudden Comfort is currently offline
My Model: 1998 Z260 MCC 7.4L
Send Sudden Comfort:
Default trim moter and water pump
Evedently when my boat was put away i was told the trim moter didnt engage, and the inside water pump was not working as well. any one had these problems, I need to know if thier fixable and or where I can find a quality new one. the boat only has 85 hours on her.
Paul
  • Old 01-14-2009, 01:53 PM   #2
    indykoch's Avatar
    indykoch is currently offline
    Send indykoch:
    85 hours on a '98?!? Wow!!
    I don't know what they mean by the trim pump "not engaging". If there's no noise at all, I'd check the switches, wiring, and connections. A 10+ year old boat is bound to have corrosion issues in the wiring. Just make sure the connections have good contact, and trace all wiring before dumping money into a new trim pump.
    The water pump could easily be just the impellor located in the lower unit. They are a regular maintenance item, needing replacement every 3-5 years depending on conditions. Check that first. With the low hours, it could have "dry rotted". I doubt it's the pump itself.
    Ryan
    Previously - '99 Z212 Shabah
    350 Mag MPI
    Old 01-14-2009, 05:36 PM   #3
    ....and if necessary, those parts are easily obtainable thru any Mercruiser dealer.
    Old 01-15-2009, 03:34 AM   #4
    Thumbs up trim moter and water pump
    thanks for the imput. Yea she is clean as the day origionally purchased. I will check all the wiring on the trim moter and most importantly the fluid level. As far as the water pump I mean the one in the engine comp hat pumps the water to the sinks, not the engine water pump thank god!!
    Old 01-15-2009, 04:18 PM   #5
    aquaknot's Avatar
    aquaknot is currently offline
    My Model: z222 shabah
    My Engine: 7.4l EFI-Bravo 1
    Send aquaknot:
    I had trouble with my trim last year as well. Noticed the fluid was very low, filled and everything was OK, for about a week. Noticed the fluid level low again, luckily it was leaking through the resevoir cap, used a little plummers tape as a quick fix and no more trouble.....still looking for a new cap
    Tod
    1999 Mariah Z222, 7.4L MPI
    2004 Lowe 16 ft aluminum, 25hp 4stroke
    1995 pontoon 18 ft, 50hp mercruiser
    198? aluminum 14ft, 6.6hp fisherman
    Water pump for sink [email protected] General Maintenance 5 03-23-2015 06:01 PM
    7.4l water pump edward cossey Projects 6 02-05-2015 02:53 PM
    Bilge pump issue adornare Original Mariah Talk 12 03-29-2010 03:30 AM
    sump pump Digby Original Mariah Talk 0 07-30-2008 04:33 AM
    Water Pump Replacment- Alpha Gen2 DIY?? kadasia Original Mariah Talk 1 06-28-2008 09:20 PM
    There are 333 users
