steering slack question
Old 03-19-2009, 02:38 AM   #1
PROPNUT is currently offline
My Model: 1994 Talari 180 4.3L LX 4BBL Alpha One
Gallery Images: 4
Send PROPNUT:
Default steering slack question
I have a 94 Talari 180 that has "play" in the steering. (at least 1 inch either direction). There is no play at the stern drive so it appears that it is coming from the other end by the steering wheel. Can this be adjusted out? How do I accomplish this?
Thanks!
  • Old 03-19-2009, 02:51 AM   #2
    Default Re: steering slack question
    Thanks!
    1" of play isn't really bad but it can be a little annoying. Try removing the steering wheel & ensuring that the bolts that secure the steering box behind the dash are tight. Also, at the other end, take a look at where the steering shaft meets the gimble. There are 2 bolts that fasten the gimble ring to the shaft. Mercruiser uses a square steering cable and the two bolts can become slightly loose allowing a little play.
    Old 03-21-2009, 03:54 AM   #3
    Gallery Images: 4
    Send PROPNUT:
    Both ends checked out ok. It appears to be near the steering wheel. I was hoping there was a way to adjust it. Any more ideas?
    Old 03-21-2009, 05:02 AM   #4
    Nope. There's no adjustment in the steering head itself. Bottom line is that over time the teeth in the head simply start to wear and then slip occurs. There is always a little bit of 'slop' inherent in the steering assemblies simply due to their design. The only solution is to replace the steering assembly with a new one. If you want to eliminate any slop at all then you might want to consider a hydraulic steering unit but they are very pricey.
    One other thing to check is the belt on the steering pump. If they're a little loose it might show up as 'slop' in the steering.
    Old 03-21-2009, 03:35 PM   #5
    Gallery Images: 4
    Send PROPNUT:
    Thanks Mikey. I will continue to investigate. I appreciate the help!
    BTW, nice looking Shabah you have there!
    Propnut
    Old 06-28-2009, 08:17 PM   #6
    1999Mariah's Avatar
    1999Mariah is currently offline
    My Model: 1999 Shabah 182 Merc 3
    Send 1999Mariah:
    I believe I have something similar, where the slop is in the 'back mount rack system' just behind the steering wheel. I imagine I can replace just that part and retain the cable?
    Old 06-28-2009, 10:34 PM   #7
    1999Mariah's Avatar
    Send 1999Mariah:
    Nope, one piece... I think I would like to go to rotary steering, does anyone know what the exact length of the steering cable would need to be? Has anyone gone to rotary steering from rack/pinion? and what's my steering cable lenght??
    Old 07-01-2009, 01:34 AM   #8
    1999Mariah's Avatar
    Send 1999Mariah:
    No one know's the steering cable length in a 182 Shabah?
    Any idea where I can find it?
    Old 07-01-2009, 08:20 PM   #9
    Hi PROPNUT,
    Do you have tilt steering? We have it on our Talari and the "U" joint couplers had come loose. If you take the wheel and rubber collar off, turn the shaft and you'll be able to see if that's part of your problem.
    Old 07-03-2009, 03:54 AM   #10
    Gallery Images: 4
    Send PROPNUT:
    Thanks, I will check it out. I do have tilt steering.
    Propnut
    Steering on '96 Shabah jchemotti General Maintenance 5 05-15-2010 08:44 PM
    Steering Lube jakejorgenson General Maintenance 1 01-27-2009 03:25 PM
    2350 Z power steering cleah Mercury MerCruiser 2 09-09-2008 02:17 AM
    Steering problems joshandsony Original Mariah Talk 2 07-22-2008 06:59 PM
    Power Steering boarder1010 Boating 101 2 07-08-2008 03:38 AM
    There are 327 users
