steering slack question
Old 07-08-2009, 04:22 PM   #11
SEMIJim's Avatar
SEMIJim is currently offline
My Model: 182 Barchetta
Send SEMIJim:
Default Re: steering slack question
Be interested in what you find, propnut, because we have the same problem. I haven't started trouble-shooting it yet.
It is annoying. Coupled with the fact I'm new at this, at slow speeds I weave back-and-forth like a drunken sailor
Jim
  • Old 07-08-2009, 04:29 PM   #12
    Z 202's Avatar
    Z 202 is currently offline
    My Model: Mariah Shabah 202
    My Engine: 5.7L Alpha 1
    Send Z 202:
    Slow speed "wander" is very typical on powerboats. Your best approach is to avoid trying to contstanly correct it. You wind up looking more like a drunken sailor...
    My Mariah
    Old 07-08-2009, 05:57 PM   #13
    SEMIJim's Avatar
    Send SEMIJim:
    Yeah, I know. Friend that was with us yesterday joked that it was a good thing I had registration and equipment all in order, cuz if one of the water cops saw us, he'd be almost certain to want to take a look
    (Actually, we did pass a county sheriff's patrol going the other way, and he never looked twice.)
    Every one-in-a-while, probably when I'm not concentrating on it, I get it right and we steer a fairly non-drunken line for a while .
    Jim
    Old 07-10-2009, 06:07 PM   #14
    SEMIJim's Avatar
    Send SEMIJim:
    Hi PROPNUT,
    Do you have tilt steering? We have it on our Talari and the "U" joint couplers had come loose. If you take the wheel and rubber collar off, turn the shaft and you'll be able to see if that's part of your problem.
    WW, we have tilt steering on our '94 182 Barchetta, and, as I mentioned already, she's got a bit of slack in the steering. Is the wheel removed by removing those half-dozen or so flat-head screws around the perimeter of the steering wheel hub? Does the rubber flex collar then just come right off?
    When I was under the dash, messing with fuses, yesterday, I noticed that as I slightly turned the wheel, that square bar under there moved back-and-forth a bit. Looked like the hardware that secures that could use a bit of tightening, too. Safe to do?
    Jim
    Old 07-10-2009, 08:27 PM   #15
    vkrishan is currently offline
    My Model: 1994 Z225 Davanti 5.7L Merc Bravo III
    Send vkrishan:
    I have a 94 Z225 with Tilt steering as well.. Was a bit annoyed at my steering slop too.. Pictures Please... Pictures on what you do find...
    Steering on '96 Shabah jchemotti General Maintenance 5 05-15-2010 08:44 PM
    Steering Lube jakejorgenson General Maintenance 1 01-27-2009 03:25 PM
    2350 Z power steering cleah Mercury MerCruiser 2 09-09-2008 02:17 AM
    Steering problems joshandsony Original Mariah Talk 2 07-22-2008 06:59 PM
    Power Steering boarder1010 Boating 101 2 07-08-2008 03:38 AM
    There are 191 users
