Smart Tabs
Old 07-05-2013, 09:34 PM   #221
rhinoz is currently offline
Send rhinoz:
Default Re: Smart Tabs
After finally been able to get on a large lake after installing the smart tabs, all I can say is "WOW". The difference is night and day. Up on plane very fast and makes the turns like its on rails. A+++ for the smart tabs
Mine are set on the middle setting.
1996 Mariah Shabah 180 (Ms. Whiplash)
Thank you rhinoz for this useful post!
hrayner (11-15-2014)
  • Old 07-05-2013, 10:42 PM   #222
    husker_fan's Avatar
    My Model: 192 Barchetta
    My Engine: 4.3L Alpha I
    Send husker_fan:
    I don't seem to need to trim up hardly at all either. Move it up much and I can start hearing the exhaust. Normal too?
    Old 07-06-2013, 12:49 AM   #223
    rayzorback's Avatar
    My Model: 210 LE
    My Engine: 454 Bravo 1
    Gallery Images: 10
    Send rayzorback:
    Loved mine.
    Old 07-29-2013, 07:06 PM   #224
    raulston88's Avatar
    raulston88 is currently offline
    My Model: z212 shabah
    My Engine: 5.7L
    Send raulston88:
    still new to the site, but have done quite a bit of reading here, and after seeing mikeyt's numerous comments on the Nauticus Smart Tabs, I did a search to find out what the ruckus was about and found this old thread.... read the whole thing, and just ordered the SX9510-80 for my Z212 w/5.7L.
    Just from reading, it sounds like the #80 should be what I need. Considered the SX10512-90, but figured my boat was on the small-ish end for those, and the 9510 with the #80 should be fine...
    I'll probably have to move my transducer...maybe.
    BTW, iboats is still selling them for ~$107.....
    Chris R
    2000 Z212 Shabah, 5.7L VP
    Old 07-29-2013, 07:16 PM   #225
    Nauticus will exchange the actuators for you free of charge if they are too "light".
    Old 07-29-2013, 10:05 PM   #226
    Paul F's Avatar
    Paul F is currently offline
    Gallery Images: 4
    Send Paul F:
    Husker fan,
    We've got the same hull. I can usually trim mine to the upper limit without any blow out.
    Not sure what that means if yours is blowing out early. Does the bow try to plow or does it trim up nicely without porposing?
    Old 07-31-2013, 07:09 PM   #227
    husker_fan's Avatar
    Send husker_fan:
    Mine won't go nearly that far. I trim all the way down and all I do is give the switch a few clicks up. Much more and I hear the exhaust. I've never had a boat before this one, so its hard for me to judge what is normal either. Maybe my trim gauge is goofy too. Full speed it shows less than 1/4 up from bottom.
    Old 07-31-2013, 09:04 PM   #228
    voodoo's Avatar
    voodoo is currently offline
    My Model: Davanti
    My Engine: 5.7
    Send voodoo:
    Question.
    When you trim all the way down do the rams fully retract?
    The trim sensor is adjustable. When it's trimmed all the way down you can loosen the two mounting screws and rotate the sensor so the gauge reads fully down.
    I've got new sensors and adjusted them as per spec. My trim range, as per the gauge goes from "down" to "half" and the limit kicks in.
    No big deal. Trimming is more done by feel, speed and how the boat reacts. Can't say I look at the gauge very often.
    The other sensor is a trim limit sensor, it too is adjustable. It controls the rams so you can't "trim up" past a safe point of angle while the drive is in use. You measure how far the rams have extended and at a prescribed point it stops "trimming up".
    Using the trailer button overrides this safety.
    All the instruction on adjustment can be found online.
    Old 08-23-2013, 06:10 PM   #229
    gahooligan's Avatar
    My Model: 202
    My Engine: 5.7l
    Send gahooligan:
    just got the smart tabs installed and ready to hit the lake this weekend the question is do you still trim all the way down when taking off or is it no longer necessary
    Old 08-23-2013, 06:28 PM   #230
    Andy b's Avatar
    Andy b is currently offline
    My Model: Diablo 180
    Gallery Images: 9
    Send Andy b:
    No still trim all the way down for take off
    just drive it like you normally would, it'll just be a nicer boat to drive
    Total Threads: 13,324
    There are 376 users
