Throttle issue
Old 05-17-2021, 04:21 AM   #1
Jerry Keane is currently offline
My Year: 1991
My Engine: 4.3 v6
Send Jerry Keane:
Default Throttle issue
1992? original Quicksilver Throttle. It will go from neutral into forward and reverse without compressing the handle release. Engine won't turn over. Can I assume neutral locking pin is broken? and if so is it repairable?
  • Old 05-17-2021, 09:55 PM   #2
    Default Re: Throttle issue
    Yes and Yes.
    File Type: docx Commander 3000 disassembly & diagram.docx (52.1 KB, 7 views)
    Old 05-17-2021, 10:31 PM   #3
    My Year: 1991
    My Engine: 4.3 v6
    Send Jerry Keane:
    Thanks Mikeyt for the reply. My throttle is not the 3000. I found diagram for the throttle mechanism but not for inside the "box" housing to see how the neutral pin is configured.
    Old 05-18-2021, 01:11 AM   #4
    Sorry, that's the only documentation they have on this site. You could always try one of the other larger boating forums such as 'iboats' and someone there may have a diagram/photo of your throttle assembly.
    Old 03-22-2022, 02:04 PM   #5
    wgoeden is currently offline
    Gallery Images: 1
    Send wgoeden:
    Were you ever able to find the part or a diagram for this issue?
    I am also having the same issue but my throttle control is a side mount Volvo Penta and I am unable to find a parts diagram or part numbers related to this controller.
    I would appreciate any help on this.
    Thanks!
    Old 03-23-2022, 01:19 PM   #6
    Hudson River Steve's Avatar
    My Model: Z280
    My Engine: 7.4L MPI Bravo3
    Send Hudson River Steve:
    I have never worked on a volvo penta shifter however it looks very similar to the Merc design which I have had the "pleasure" of working on. On my Merc control I need to remove the black plastic pushbutton by prying it out with a screw driver. This will damage the pushbutton so you will need to replace it. Once out you can free up the mechanism using some WD40 and then replace the button. I had to do this a couple of times throughout the years.
    Hudson River Steve
    1999 Z280
    7.4 MPI, Bravo3
    Old 03-23-2022, 01:45 PM   #7
    Gallery Images: 1
    Send wgoeden:
    When you say to pry out the black push button, I have an exterior white nylon button that passes through a hollow bolt and there is a black plastic button inside. Is that the black pushbutton you are referring to? I took it apart yesterday and stopped as it looked like there is no way to open it up to get to the black push button and what is behind it. I was thinking I would have to replace the entire controller and possibly the control cables. As I have no part numbers on anything I wouldn't know where to find the black plastic button or even a complete controller.
    If you have any part numbers or a source where you got your button I would appreciate it.
    Old 03-23-2022, 02:00 PM   #8
    My Model: Z280
    Again, I was referring to a Mercruiser control. On the Mrec control, the black pushbutton has a rather long shaft that passes through a hollow bolt with a plastic barb on the end of it. It was easier for me to pry it out, breaking the plastic barb on the end and then lubricate and replace the plastic button. I do not recall where I sourced the replacement plastic button. I wonder if the Volvo Penta control is made by Morse...just a thought.
    Hudson River Steve
    1999 Z280
    7.4 MPI, Bravo3
    wgoeden (03-23-2022)
    Old 03-23-2022, 02:09 PM   #9
    Gallery Images: 1
    Send wgoeden:
    Thank you!
    Throttle Question RichB Original Mariah Talk 1 04-19-2011 04:14 PM
    Throttle question theeasynine Mercury MerCruiser 1 04-15-2011 10:26 PM
    throttle issues murphysocc Mercury MerCruiser 5 07-07-2010 10:26 PM
    Throttle handle roger simkin Mercury MerCruiser 1 01-01-2010 09:40 AM
    Throttle Arm assembly? trussman Original Mariah Talk 1 07-07-2009 12:08 PM
    There are 353 users
