Shabah 182 dashboard
Old 10-21-2020, 10:06 AM   #1
Lewy is currently offline
My Model: 182
My Engine: 4.3L mercriuser
Send Lewy:
Default Shabah 182 dashboard
Does anyone have experience or knowledge of how to remove the dashboard on a 182?
Need to check wiring and connections as i think might have an earth issue.
Seems really trick to get to the instrument panel from behind or underneath.
many thanks
Lewy
  • Old 10-21-2020, 11:56 AM   #2
    Default Re: Shabah 182 dashboard
    Look in the "Projects & Add Ons" section under the "How To" threads and you will find what you need. Be aware though that where the dash is bolted / screwed to the fiberglass has very likely become brittle due to age and there is a good possibility you will crack or break the connecting points when removing / replacing the dash. Speaking from experience....
    For my 180, i simply remove the kick panel on the drivers side then prop my head/shoulders up with a couple of life jackets / pillows for a bit of comfort and work on that stuff from underneath.
    Dashboard help! TonyTerriRush Introductions 2 06-04-2017 05:11 PM
    Dashboard discoloration jjk61083 Original Mariah Talk 3 07-25-2012 05:54 PM
    Wanted: Dashboard Repair pblouin Mariah Parts For Sale & Wanted 5 12-25-2010 04:20 AM
    Need help With dashboard Removal niceguy167 Original Mariah Talk 2 06-08-2009 02:08 PM
    Dashboard woe's blockp Original Mariah Talk 2 10-15-2008 03:13 PM
    There are 298 users
