1994 Z222 Bravo 1
Old 04-18-2019, 03:24 AM   #1
Juttkc is currently offline
Send Juttkc:
Default 1994 Z222 Bravo 1
Last year I had the gimbal bearing replaced in my Bravo 1. This year I noticed the trim gauge was off. I went ahead ant trimmed to the full up position (not trailer mode) and measured the distance between the ram pins at 25”. According to some online files this measurement should be 21 3/4”. If the limit switch is set to this value that only leaves 3” of inward trim before hitting the stop pin in the down position. Does this sound right?
Also, is full trim the second to last dash on the trim gauge and the last being trailer mode?
    97 Shabah Z222 5.7 LX/EFI Bravo III joshjnm Introductions 0 06-16-2018 03:17 PM
    97 z222 Fisher49 Introductions 0 05-07-2018 01:48 AM
    1994 Z222 Top Speed juttmk Original Mariah Talk 6 06-05-2017 11:17 PM
    1994 z222 7.4 Alpha 1 Prop Help juttmk Prop Talk 2 07-12-2016 03:06 AM
    5.7 Bravo 3 Vs. 7.4 Bravo 1 Talari Ikepieman Original Mariah Talk 7 07-04-2016 02:48 AM
    There are 388 users
