211 drain plug
Old 09-11-2017, 10:07 PM   #1
DCA Thread Starter
DCA is currently offline
My Year: 99
My Model: 211
Send DCA:
Question 211 drain plug
Hi Everyone, I just purchased a 1998 211 cuddy with 4.3. I noticed a lot of water when i removed the drain plug however the engine bay was dry prior to removing the plug. Is the drain connected to the engine compartment or below?
  • Old 09-12-2017, 07:12 PM   #2
    Scottie1961's Avatar
    Scottie1961 is currently offline
    Status: Gold Contributor
    My Model: Z202 Shabah
    My Engine: 5.7L Alpha One
    Send Scottie1961:
    Default Re: 211 drain plug
    My Shabah is a bowrider of course, but there is a drain hole coming from the compartment housing the gas tank into the engine compartment. I believe the bow area drains under the floor and through that drain hole. In theory water could accumulate in that area.
    Was the boat at a different attitude when you checked the engine compartment? Maybe water ran back to the drain when you raised the bow?
    1995 Mariah Z202 Shabah
    5.7 Alpha One Gen II
    Old 09-15-2017, 03:37 PM   #3
    DCA Thread Starter
    My Year: 99
    My Model: 211
    Send DCA:
    [QUOTE=Scottie1961;63912]My Shabah is a bowrider of course, but there is a drain hole coming from the compartment housing the gas tank into the engine compartment. I believe the bow area drains under the floor and through that drain hole. In theory water could accumulate in that area.
    Was the boat at a different attitude when you checked the engine compartment? Maybe water ran back to the drain when you raised the bow?[/QUOTE
    Thanks, heres the thing, i put her in the water last week, then pulled her out, while on traler at noat ramp with a slope i checked engine compartment where bilge pump is at it was dry, i pulled plug and drained 3 to 4 gallons of water.
    I onle can verify only 1 bilge pump in the engine compartment, cant figure why i can drain hidden water when the bilge pump is dry?
    Old 09-15-2017, 06:59 PM   #4
    Send Scottie1961:
    Yeah doesn't make sense. I wonder if the boat was on such a steep slope (boat ramp) that the water was sitting against the transom and you couldn't see it under the engine. At least on mine, the bilge pump sits towards the front of the engine so in theory water could be at the very back (stern) of the engine compartment and not be visible under the bilge pump.
    I can't imagine the plug opening being lower than the bottom of the engine compartment but hey I'm just a dumb IT guy
    Drain plug Kerberajen Original Mariah Talk 10 06-19-2020 05:56 PM
    drain plug Dbergster Introductions 2 08-17-2016 03:40 PM
    '96 Talari drain plug mike523 Original Mariah Talk 2 03-29-2016 12:51 AM
    drain plug LED Oregondunes Other For Sale 14 08-06-2014 10:38 PM
    location of oil drain plug nana Original Mariah Talk 1 09-19-2011 03:55 PM
    There are 479 users
