Drain plug
Old 05-15-2017, 03:51 AM   #1
Kerberajen's Avatar
Kerberajen is currently offline
My Model: 250 Shabah
My Engine: 454 Bravo I
Send Kerberajen:
Post Drain plug
We are new to owning a Mariah boat! With our other boats we always took out the drain plug out and never kept it in. We were told that the drain plug on the Mariah is hooked to a cable and if pulled will drain the oil in the engine. We don't like this feature on the drain plug and wasn't sure if anyone know if we could clip the plug off and the cable to the oil be fine?
Firestone and ROY850 like this.
  • Old 05-15-2017, 04:04 AM   #2
    My Model: Z202
    Send Firestone:
    Default Re: Drain plug
    My 2000 z202 does not have that feature.
    John
    Old 05-15-2017, 08:07 AM   #3
    pllevine's Avatar
    pllevine is currently offline
    My Model: 202 Shabah
    My Engine: 5.0L Alpha
    Send pllevine:
    Huh? Are we talking about the drain plug to the bilge? If your engine oil drains when you remove your bilge drain plug, you have bigger problems.
    Seriously though, my Mariah has a drain plug (actually I have three... one for use and I keep two spares onboard) and there is no connection to the two.... nasty bilge water and engine oil.
    Phil Levine
    1998 202 Shabah
    The Following 2 Users Say Thank You to pllevine For This Useful Post:
    1996 Mariah Z252 (05-15-2017), ROY850 (05-15-2017)
    Old 05-15-2017, 03:45 PM   #4
    ROY850 is currently offline
    My Engine: 4.3L alpha one
    Send ROY850:
    Same here 99 202 shabah only have a water drain plug, no oil drain plug.
    Old 05-15-2017, 09:25 PM   #5
    GaryDoug's Avatar
    GaryDoug is currently offline
    My Model: Z202
    My Engine: 5.7L Bravo III
    Send GaryDoug:
    There is a "cable" on my drain plug, but it is an electrical cable for the type of drain plug that has a light. No releasing anything.
    Old 05-16-2017, 12:31 AM   #6
    pllevine's Avatar
    Send pllevine:
    The light embedded in your drain plug is just the cost efficient way of having a stern mounted underwater light.
    It has nothing to do with oil, bilge water, or the cost of tea in China. It's just supposed to be pretty to look at.
    Phil Levine
    1998 202 Shabah
    Old 05-16-2017, 12:38 AM   #7
    GaryDoug's Avatar
    My Model: Z202
    Send GaryDoug:
    Well, as an electrical engineer, I think I understand that ;-) I just mentioned it in case he saw the same wire on his.
    Underwater Lights
    The Following 2 Users Say Thank You to GaryDoug For This Useful Post:
    Firestone (05-16-2017), ROY850 (05-25-2017)
    Old 05-25-2017, 05:29 PM   #8
    Never heard of this feature with Mariah at all, and I had a 2000 Z250LE previously. If you've got something like this, it wasn't anything that was done at the factory.
    Old 05-25-2017, 05:56 PM   #9
    pllevine's Avatar
    Send pllevine:
    It's an aftermarket add on
    Phil Levine
    1998 202 Shabah
    Old 06-19-2020, 05:33 PM   #10
    mrspepsi is currently offline
    My Model: 180
    My Engine: 3liter
    Send mrspepsi:
    Our drain plug is missing, where can I purchase one?
    drain plug
    drain plug Dbergster Introductions 2 08-17-2016 03:40 PM
    '96 Talari drain plug mike523 Original Mariah Talk 2 03-29-2016 12:51 AM
    drain plug LED Oregondunes Other For Sale 14 08-06-2014 10:38 PM
    Maybe a stupid drain plug question... gahooligan Original Mariah Talk 8 04-15-2014 01:32 AM
    location of oil drain plug nana Original Mariah Talk 1 09-19-2011 03:55 PM
    Total Threads: 13,324
    There are 284 users
