Z275 Shabah Tachometer & Speed Indicator
Old 06-23-2017, 08:32 PM   #1
bisham is currently offline
Send bisham:
Default Z275 Shabah Tachometer & Speed Indicator
Has anyone had trouble with these gauges not working? I am trying to save a little time troubleshooting. Neither the tach or the speed indicator are working. Any help for troubleshooting techniques would be greatly appreciated.
  • Old 06-23-2017, 08:37 PM   #2
    My Model: Z202
    Send Firestone:
    Default Re: Z275 Shabah Tachometer & Speed Indicator
    Do a search in the forus. You will find all kinds of info. I know my tachometer was acting up I rotated the engine selector on the back of it, but it never stopped working. Do the verify that the water line to the speedometer was unobstructed?
    John
    Old 06-23-2017, 08:40 PM   #3
    pllevine's Avatar
    pllevine is currently offline
    My Model: 202 Shabah
    My Engine: 5.0L Alpha
    Send pllevine:
    I KNOW that there was a post not long ago about the blocked speedometer "pitot tube" on the front edge of the lower outdrive. They said to take a small drill bit and twist it into the hole to clear out whatever was blocking it. I did this and my speedometer came right back. The speedometers work with direct water pressure through a tube right into the back of the gauge....
    The tachometer had something to do with rotating the cylinder select switch around to dislodge any corrosion or build up in the switch.....
    Phil Levine
    1998 202 Shabah
    Old 06-24-2017, 02:20 PM   #4
    Send bisham:
    I will try those. Right now the boat is in the water while we get our trailer repaired. We will get the trailer back next week, pull the boat and I will try these. Thanks.
    Z210 Shabah Top Speed mark43 Original Mariah Talk 44 06-27-2019 11:10 PM
    Trim indicator Medic1 General Maintenance 1 06-15-2016 09:57 AM
    Z275 Top Speed Naughty Dog Original Mariah Talk 7 06-10-2011 10:06 PM
    1996 Shabah 180 3.0 top speed? midwest mariah Original Mariah Talk 4 08-03-2009 04:43 AM
    tachometer for 2000 182 Shabah RodneyWest Original Mariah Talk 8 05-05-2009 02:56 AM
    There are 319 users
