Z275 Shabah Dual Trim Tab Rocker Switch Replacement
Old 06-17-2017, 05:06 PM   #1
bisham is currently offline
Send bisham:
Default Z275 Shabah Dual Trim Tab Rocker Switch Replacement
One of my trim switches was bad. Could not find an exact replacement. Ended up purchasing a Lenco 122 Double Rocker Switch. I pulled off all of the wires and jumpers from the back of the Lenco switch, then reinstalled them to match the copper plate jumpers on the back of my original Mariah dual switch. Attached the four wires to the Mariah connector in the exact same positions and it works like a charm. The screw holes are off about 3/32" but slightly elongating does the trick. Had to remove the radio to get to the wiring.
  • Old 06-20-2017, 11:10 AM   #2
    chuse927 is currently offline
    My Model: 272z Barchetta
    My Engine: 7.4
    Send chuse927:
    Default Re: Z275 Shabah Dual Trim Tab Rocker Switch Replacement
    My trim switch is bad as well. Up not functioning well on my 272. Do you mind posting a photo so I can see if we are talking about the same set Up?
    Sent from my SM-N920V using Tapatalk
    Old 06-21-2017, 11:39 PM   #3
    Send bisham:
    Yes, I will get a photo of the new switch installed and the back of the old switch and post them.
    Firestone and chuse927 like this.
    Old 06-22-2017, 12:19 AM   #4
    My Engine: 7.4
    Send chuse927:
    Old 06-23-2017, 08:29 PM   #5
    Send bisham:
    Here is a photo of the new switch installed and of the back of the old switch. The color wires on the old switch are the wires that go to the connector. Jumper the back of the new switch to match the copper connections on the old switch so you end up with the 4 connecting wires in exactly the same place on the new switch.
    Old 06-23-2017, 08:31 PM   #6
    My Engine: 7.4
    Send chuse927:
    Was this for trim tabs or lower unit trim? My issue is lower unit trim switch
    Old 06-23-2017, 08:33 PM   #7
    Send bisham:
    This was for the dual trim tabs.
    Thank you bisham for this useful post!
    chuse927 (06-23-2017)
    Rocker Switch labels Motoxxx43 Sea Fox - Mariah Talk 6 05-05-2014 03:08 PM
    Wanted: Rocker Switch needed Saucy1 Mariah Parts For Sale & Wanted 5 02-01-2014 05:24 PM
    circuit board rocker switch cp55 Original Mariah Talk 0 05-12-2012 03:14 PM
    1996 Z275 SHABAH Cabin dual light fixtures Cinnamon Original Mariah Talk 7 07-02-2011 03:55 AM
    Outdrive Trim Sensor & Trim Limit Switch Replacement WetWilly General Maintenance 0 05-26-2009 06:01 AM
    There are 272 users
