Mariah Z198 Shabah fuel pump change
Old 08-30-2016, 05:30 PM   #1
Magic52 is currently offline
My Model: Z198 Shabah
My Engine: Mercury 350 magnum mpi
Send Magic52:
Default Mariah Z198 Shabah fuel pump change
Hi all, i got my mariah at the mecanic, and he says I have to change the fuel pump but he says he has to take the engine out to do so because there is no space, the engine is the Mercruiser 350 Magnum MPI Gen + Bravo three.
The problem is that he doesn´t know how to take out the engine because he says there is no space because when they made the boat they first introduced the engine and afterwords the top of the boat and he can´t use the engine holes to bring it up.
Any idea of how to get out the engine or how to change the fuel punp?
Sorry about my english i am writing from spain
Thanks everyone
  • Old 08-30-2016, 07:23 PM   #2
    Hudson River Steve's Avatar
    My Model: Z280
    My Engine: 7.4L MPI Bravo3
    Send Hudson River Steve:
    Default Re: Mariah Z198 Shabah fuel pump change
    Sounds like you need a new mechanic. The fuel pump is located way down low on the side of the engine. It is very difficult to access but a good mechanic can usually find a way to get the job done. Same for the engine removal, he may have to remove the front drive accessories and then the rear seat and sun pad to lift the motor a little, drag it forward and then out of the boat. All things are possible.
    Hudson River Steve
    1999 Z280
    7.4 MPI, Bravo3
    Firestone (09-02-2016)
    Old 08-31-2016, 10:07 AM   #3
    pllevine's Avatar
    pllevine is currently offline
    My Model: 202 Shabah
    My Engine: 5.0L Alpha
    Send pllevine:
    Think your mechanic needs to purchase a Seloc manual on the 350 Mercruiser.... That way, he can turn to the section titled 'Fuel Pump Removal'....
    1998 202 Shabah 5.0L Alpha 1
    Phil Levine
    1998 202 Shabah
    Old 08-31-2016, 10:15 AM   #4
    pllevine's Avatar
    Send pllevine:
    Phil Levine
    1998 202 Shabah
    Old 08-31-2016, 09:34 PM   #5
    Send Magic52:
    Hi again, thanks for the quick responses, this is my first time with this mechanic and i am not sure if he is the right one.
    Question, will I be able to remove the fuel pump with out removing the engine from my Mariah?
    Since the boat is 20 years old and I just bought it is it worth to remove the engine and check any other parts? I have no experience with boats but I have some experience in do it yourself with motorcycles
    Where can I get the part? Is there any good web to get mercury parts?
    I have other question-problems i would like to ask but i want to get the boat back in water before starting with electrical issues.
    Thanks again everyone
    Fuel Pump change mercruiser v6 2000 guyjusthere Mercury MerCruiser 7 10-26-2013 06:58 PM
    1997 Z198 Mariah Shabah wredskinsfan32 Mariah Boats For Sale & Wanted 0 10-02-2013 03:04 PM
    1996 Mariah Shabah 200 oil change nrwhitek Introductions 8 04-08-2011 07:31 AM
    Prop change to improve fuel useage? ryker137 Prop Talk 5 06-29-2009 04:20 PM
    There are 443 users
