Hinges for rear vinyl sun deck
Old 07-30-2016, 07:53 PM   #1
mike523 is currently offline
My Model: Talari
My Engine: 4.3 Mercruiser
Send mike523:
Default Hinges for rear vinyl sun deck
I'm assuming a set of hinges went here, does anyone know where I can find a set?
  • Old 08-01-2016, 12:00 AM   #2
    pllevine's Avatar
    pllevine is currently offline
    My Model: 202 Shabah
    My Engine: 5.0L Alpha
    Send pllevine:
    Default Re: Hinges for rear vinyl sun deck
    Not sure about the Talari. On the 202, the single piano hinge is dead center and screwed in a horizontal position just above the engine, so you can't easily see it. There is a "hinge block" that is a 1.5" square by about 8" long screwed to the sun deck using T-Nuts and the piano hinge is screwed into the hinge block on the perpendicular side...
    1998 202 Shabah 5.0L Alpha 1
    Phil Levine
    1998 202 Shabah
    Old 08-01-2016, 12:04 AM   #3
    pllevine's Avatar
    Send pllevine:
    Phil Levine
    1998 202 Shabah
    Old 08-01-2016, 12:05 AM   #4
    pllevine's Avatar
    Send pllevine:
    Phil Levine
    1998 202 Shabah
    Old 08-01-2016, 12:08 AM   #5
    pllevine's Avatar
    Send pllevine:
    New Starboard Sun Deck
    Phil Levine
    1998 202 Shabah
    Old 08-01-2016, 12:10 AM   #6
    pllevine's Avatar
    Send pllevine:
    Original Sun Deck
    Phil Levine
    1998 202 Shabah
    Hinges 00 diablo 00 Original Mariah Talk 7 05-05-2020 07:07 PM
    rear deck over engine- whats the frame made of? Txtruckerpaul Original Mariah Talk 5 02-23-2014 03:11 AM
    bench hinges tfn1977 Original Mariah Talk 11 10-31-2011 09:05 PM
    Gas Spring struts rear sun deck Billyclub Original Mariah Talk 0 05-06-2009 06:32 PM
    Sundeck hinges jkboliphant Original Mariah Talk 11 04-24-2009 02:02 PM
    There are 456 users
