Sundeck hinges
Old 04-11-2009, 03:34 PM   #1
jkboliphant is currently offline
My Model: 1995 Z192 Barchetta 5.0L Alpha One
Send jkboliphant:
Default Sundeck hinges
Does anyone out there have pictures of their sundeck hinges? I have a Z and the people I bought it from said that the power actuator for the sundeck was removed before they bought it and now the sundeck doesn't open very far so I am curious how the current hinges installed compare to what the factory hinges look like/operate. Thanks.
  • Old 04-12-2009, 01:08 PM   #2
    Default Re: Sundeck hinges
    Do you have a photo of your hinges you could post? I'll probably work on my boat today, and snap a photo of mine for you.
    Old 04-12-2009, 07:14 PM   #3
    Send jkboliphant:
    It is raining all day here today but Monday I'll snap a few and post them. Thanks.
    Old 04-13-2009, 11:40 PM   #4
    Send jkboliphant:
    Here are the pictures of my current hinges, she is dirty which is partly because the sundeck doesn't open very high therefore it is really difficult to get back there. I hope this helps.
    Old 04-14-2009, 12:41 AM   #5
    jeffryb is currently offline
    My Model: 1993 19ft 1900z 4.3lx alpha one
    Send jeffryb:
    Those hinges don't look stock to me, on my 93 1900Z there's only one hinge and it runs the whole length of the pad and when it's shut you don't see it on the back. I'll have to uncover it and take a picture.
    Old 04-14-2009, 02:01 AM   #6
    Send jkboliphant:
    I'm positive they are not stock because you can see where either the old hinges were mounted or where the old power hatch units were in place because there are screw holes in the fiberglass where the factory mounts should be. Any help on what type of hinges this baby should have so that I can have better access would be greatly appreciated.
    Old 04-14-2009, 03:00 AM   #7
    rooperdan's Avatar
    rooperdan is currently offline
    My Model: 1998 SHABAH 210
    My Engine: Built 350 Alpha Drive
    Gallery Images: 10
    Send rooperdan:
    The hinges you have there are a 5 knuckle door hinge.
    You should look at a stainless steel continuous piano hinge 1 -1/2 inch by 72 inch.
    Old 04-16-2009, 06:50 PM   #8
    Send jeffryb:
    Here are some picture's of my hinge on my sun pad. Hope they help.
    Old 04-17-2009, 02:12 AM   #9
    Send jkboliphant:
    Thanks for posting those pics, the more I see all the other Mariah's on here the more I feel as though my Mariah was royally molested. Oh well, there is that added satisfaction I will have when I get her back where she belongs. I also noticed that my sundeck has two sets of door hinges, one set mounted on the outside and the other set is actually mounted underneath, which is why it doesn't open very far. Thanks again.
    Old 04-17-2009, 04:15 AM   #10
    bdbyrnes's Avatar
    bdbyrnes is currently offline
    My Model: Talari z240
    My Engine: 7.4L V8 - Bravo III
    Gallery Images: 41
    Send bdbyrnes:
    I am afraid what is on there are not the correct hinges. They should not be visible at all and the swimdeck cover should be higher than it appears yours is.
    When I had my swimdeck cover recovered last year I mounted the hinge incorrectly and the cover barely opened. With the correct hinge the cover opens almost all the way vertical....
    Brent
    1995 Talari Z240
    7.4L Merc, Bravo III Outdrive
    Corsa Performance Captains Call Exhaust
    Samson Sports Tower
    bench hinges tfn1977 Original Mariah Talk 11 10-31-2011 09:05 PM
    Help with power sundeck/motor lid jasfiveo Original Mariah Talk 14 04-03-2010 11:05 PM
    Bench Seat Hinges Kuli Original Mariah Talk 1 05-01-2008 12:33 PM
    There are 438 users
