low oil pressure
Old 06-06-2014, 01:07 AM   #11
dusty72 is currently offline
My Model: mx19
My Engine: 4.3lx
Send dusty72:
Default Re: low oil pressure
ok, all connections cleaned. there was a little corrosion at the sender. we will see what happens when I take it out Saturday.
Should I start a new thread for the tachometer? It just sits on 50 and doesn't move. I can move the dial with a magnet though. It is a Faria.
  • Old 06-06-2014, 02:18 AM   #12
    Same possible issues (poor connections) with the tach. There is also a small dial on the back of the tach that reads 2-4-6-8. Give the dial a spin a few times then re-set it to 6 cyl and see if that helps. If it isn't the connections & the 'spin the dial' trick doesn't resolve it then its likely time for a new tach.
    Old 06-06-2014, 02:21 AM   #13
    My Model: mx19
    My Engine: 4.3lx
    Send dusty72:
    Tried all that. Oh well, I will see if Faria really does have a lifetime warranty.
    Old 06-06-2014, 11:39 AM   #14
    My Model: mx19
    My Engine: 4.3lx
    Send dusty72:
    You fellas have been g great! One last question. Where are the connections for the tach o the engine? I have only checked the ones to the gauge itself.
    Old 06-06-2014, 11:40 AM   #15
    My Model: mx19
    My Engine: 4.3lx
    Send dusty72:
    Is anyone from Texas?
    Old 06-06-2014, 12:50 PM   #16
    Hudson River Steve's Avatar
    My Model: Z280
    My Engine: 7.4L MPI Bravo3
    Send Hudson River Steve:
    Connections for the tach on the engine are in the wiring harness to the ignition coil on the engine. I have never heard of a problem there...it is always corrosion on the printed circuit within the Faria tachometer that causes the problem. I know you said you tried it but I suggest you try to rotate the 4/6/8 dial on the back of the tach again...this time try pushing in on dial while you spin it. The only other suggestion is to remove all the wires and slightly loosen the nuts on the BATT, GND & SIG studs on the rear of the tach, spin them as much as you can (they are captured within the gauge) and then reassemble everything. The internal electronics of the tach are bullet proof...the weak link in Faria's design is corrosion of the electrical connections from the brass studs to the printed circuit board and the selector switch.
    mikeyt and woodward33 like this.
    Hudson River Steve
    1999 Z280
    7.4 MPI, Bravo3
    Old 06-06-2014, 01:08 PM   #17
    My Model: mx19
    My Engine: 4.3lx
    Send dusty72:
    Thanks. I will give an update tomorrow night.
    Old 06-07-2014, 12:31 PM   #18
    jarwiebe's Avatar
    jarwiebe is currently offline
    My Model: Z210 Shabah
    My Engine: 5.7 LX Alpha I
    Gallery Images: 2
    Send jarwiebe:
    I concur with ensuring all connections are clean and tight as well as spinning the 4,6,8 dial. What seems suspicious is that the dial will not drop back to zero, this would suggest that either the return spring for the needle or the bearing in which the needle shaft rotates are at fault, I don't think either of these situations would be user fixable.
    Cheers
    Jake
    1996 Z210 Shabah
    Mercruiser 5.7LX
    Alpha One Drive
    80 Lb. SX Smart Tabs
    Old 06-08-2014, 04:30 PM   #19
    My Model: Z280
    Actually there is no return spring, but there is a return magnet. My money is still on high resistance due to corrosion. If there is no electrical connection on the 4,6,8 switch it will behave as if the needle is stuck.
    Sent from my iPad using Tapatalk
    Hudson River Steve
    1999 Z280
    7.4 MPI, Bravo3
    Old 06-08-2014, 05:31 PM   #20
    My Model: mx19
    My Engine: 4.3lx
    Send dusty72:
    Ok, just got back from taking her out. Oil pressure gauge works! Reads about 20 when cruising. Tach not so lu
    cky. When I turn the key over it drops to zero fro 50 going the wrong way. Afer it cranked up, went back to 50 and stayed there. I did not have my magnet with me, next time I will drag the needle back aroun to zero before I fire her up. On a side note, the speedo worked, I had browsed some threads, that was an easy fix. The hardest is going to be the trim. I might have that one done. Thanks a bunch!
    Fuel pressure? 42hut Original Mariah Talk 2 08-09-2011 01:29 AM
    Too much fuel pressure? 42hut Mercury MerCruiser 4 08-08-2011 07:46 PM
    Oil Pressure andyc Mercury MerCruiser 4 06-22-2011 08:20 PM
    Oil Pressure my97camaro General Maintenance 0 06-15-2010 03:11 PM
    Oil pressure too high??? DGR-Z246-98 Original Mariah Talk 6 11-02-2009 03:34 PM
    There are 289 users
